All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-19-2010, 04:56 PM
Gutierrez Gutierrez is offline
Default Fine grained temperature control with a Peltier/TEC
I'll preface this with I'm a computer scientist not an engineer. So feel free to correct away. I'll never learn if you don't.
I'm trying to work out a simple control for creating small temperature changes on an aluminum surface +/- 0.1C/sec to +/- 0.4C/sec. The peltier looked like a good fit for the device so I've ordered two 7w 20mm peltiers online to mess around with.
I've been looking around for simple ICs to control the TEC and I'm hunting around bi-directional motor controllers using H-Bridges. So my question is, given the ratings of the peltier, what specs should I look for in the chip or dip?
Here are the specs on the TEC:
Type: TEC1-04902
10W
Couples: 49
Imax (A): 2
Vmax (V): 5 (usually working <=5v)
QCmax (W):7
Dimensions: about 20 x 20 x 4mm
Tmax △C: 67
I read that the optimum current for a peltier is around 75% of the Imax, so I would think that means I should use a supply of 1.5A at around 4.5V (6.75 watts), is that even right?
The problem I run into is finding an IC that does that. The closest I have come that looks simple to work with is TI's L293 which outputs from 4.5V to 36V and 1A per channel.
If I were to supply 4.5V at 1A to the chip to drive the Peltier would that still work for my application?
My second problem is I need to regulate the temperature of the surface with a decently rapid response time. Is measuring off a LM35 and using the result to regulate PWM on the peltier via the L293NE a good fit? Will all the rapid temperature changes (albeit small) junk my peltier too quickly?
  #2
Old 03-19-2010, 06:50 PM
BMorse's Avatar
BMorse BMorse is offline
Default
Check out the LMD18200T H bridge:
Quote:
•Delivers up to 3A continuous output
•Operates at supply voltages up to 55V
•Low RDS(ON) typically 0.3 per switch
•TTL and CMOS compatible inputs
•No "shoot-through" current
•Thermal warning flag output at 145°C
•Thermal shutdown (outputs off) at 170°C
•Internal clamp diodes •Shorted load protection
•Internal charge pump with external bootstrap capability
Quote:
The LMD18200 is a 3A H-Bridge designed for motion control applications. The device is built using a multi-technology process which combines bipolar and CMOS control circuitry with DMOS power devices on the same monolithic structure. Ideal for driving DC and stepper motors; the LMD18200 accommodates peak output currents up to 6A. An innovative circuit which facilitates low-loss sensing of the output current has been implemented.
B. Morse
__________________
There is no spoon -Neo-
Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk!
The Following User Says Thank You to BMorse For This Useful Post:
Gutierrez (03-19-2010)
  #3
Old 03-19-2010, 07:17 PM
Default
Quote:
B. Morse
I ask for simple, you give me simple. A PWM signal will be easy to swing and this will definitely take the load I need to pass without blinking. This will be a great chip to prototype with for a single TEC. Makes me sad National Semiconductor isn't as sample happy as Texas Instruments, though.
  #4
Old 03-19-2010, 10:32 PM
Default Seek and ye shall find
Sent Texas Instruments and e-mail and it turns out that they actually produce a whole set of TEC drivers right on spec with my coolers!
Here's the list for parts in series DRV59X.
You can get chips that use an external PWM or use their own internal PWM depending upon your needs.
I'm not really in love with the fact it's PowerPad (32-HLQFP), I'd rather have straight DIP to prototype with, but I'm sure I can find/make a board to solder one to.
They also are a decent price ranging from $6.20 with no PWM to $24 with built in PWM on Digikey for each unit. And best yet... They are on the sample program!
  #5
Old 03-19-2010, 10:43 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Default
You won't likely find a DIP that can pass enough current.
Most of the newer stuff is SMT. There are very few DIP IC's that are capable of sourcing/sinking more than an amp or so current anymore. A couple of those are the IRLD014 and IRLD024; single logic-level N-ch power MOSFETs with Id=1.7A and Id=2.5A respectively.
But, you'd be better off with an integrated solution than playing around with discrete components.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #6
Old 04-16-2010, 02:43 AM
Default
I'm plugging away on the circuit design and schematics right now. I think I've got the major components and layout for it done. But I wanted to add some flair: LEDs that light showing whether the TEC is hot or cold on the top side. Luckily a coolers performance is based on current flow and PWM. And LEDs are only deal with single direction current flow and use PWM to dim. So it seems I should be able to indicate what's going on with the TEC using a blue and red LED. My problem? 1.5 Amps of current and 4.5 volts that needs to run LEDs. So how can I drive the LEDs off the PWM? I know a blue led runs around 4.5V, but what about RED leds that use lower voltage? I'm working with SMD components, but the board is up to me, so any footprint for the components is workable. From design tips to component recommendations, any help would be greatly appreciated.
  #7
Old 04-16-2010, 03:21 AM
SgtWookie's Avatar
Default
Have you tested your TEC to see what the actual voltage across it is with 1.5A and 2A applied?
Going back to look at the TEC specs, it gives a max of 2A, and 5V, but that doesn't necessarily mean the TEC has a flat response of 2.5 Ohms.
Anyway, just figure your current limiting resistors (Rlimit) as:
Rlimit >= (Vsupply - Vf_LED) / Desired_LED_Current
Use the Typ Vf @ current specification for your calculation
__________________
General info:
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Basic temperature control project ronnierohan007 Homework Help 5 11-27-2009 10:41 PM
Temperature control help. tee2 The Projects Forum 10 05-11-2009 01:42 AM
Need help for a dawn/dusk LED circuit malaybiswas The Projects Forum 24 03-04-2009 04:19 PM
temperature control help!!! temperaturehelp Homework Help 1 02-25-2009 11:15 AM
read temperature, and control a valve actuator chiswilson The Projects Forum 5 12-09-2008 05:58 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
