All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-19-2010, 04:37 AM
cheypr cheypr is offline
Junior Member
Default How to find Q point load line
Hi again, I'm trying to graph the Q point and load lines for this class A amp.
From what know Vce(max)=Vcc and Ic(max)=Vcc/Rc.
Do I got it right? How do I get Vce max and Ic max?
  #2
Old 03-19-2010, 06:23 PM
The Electrician The Electrician is offline
Default
Everything looks ok; I didn't check all the numerical results. You've made some approximations, such as in the calculation for VB where you didn't take into account the effect of the base current on the voltage divider, etc., but approximations are only approximate, right?
The one thing I see that doesn't look quite right is at the very end where you calculate Ic(max).
If you want Ic(max) when the transistor is held full on with DC drive, then Ic(max) would be something like Vcc/(100+8.2+36).
If you want Ic(max) given the 500 mV P-P input signal, that's a different calculation!
But, the problem didn't ask for Ic(max), so you're ok.
  #3
Old 03-19-2010, 09:21 PM
PRS's Avatar
PRS PRS is offline
Default
Notice the DC load line is asked for so I simplified the schematic accordingly. Follow the equations step by step and you'll see the reasoning. This is approximate. Your teacher probably wants you to use beta and/or alpha and a more exact solution for Ie. Remember the loop equation for that? More on this point if you want.
__________________
Paul
Yakima, Washington
  #4
Old 03-20-2010, 01:52 AM
Default
Reading PRS's post prompted me to go back and have another look at your work. I obviously read through it too fast!
In the second column, you have Vc =Vcc - Ic*Rc - IE*RE
You should have stopped there, and let the equation be:
Vce =Vcc - Ic*Rc - IE*RE
because when you went further, with Vce = Vc - VE, you ended up subtracting VE twice from Vc.
You would have ended up with Vce = 5.21, approximately correct.
  #5
Old 03-20-2010, 06:34 PM
PRS's Avatar
PRS PRS is offline
Default
My evaluation was a little crude, given the relatively high amount of current going into the base. You need to thevinize the input as an equivalent resistance and voltage, then write a loop that includes that, Vbe and Ie, solving it for Ie. This will give you a more exact Ve and Vc. Then use these to determine Vce = Vc - Ve. Get Ic from Beta and Ic(sat)is solved as above. Ic(sat), by the way is the total amount of current available from the source given Vcc and the resistances of the circuit. Draw the load line the same as I drew it. This should put your teacher in tall cotton when he evaluates your homework!
__________________
Paul
Yakima, Washington
  #6
Old 03-21-2010, 04:25 AM
Junior Member
Thumbs up
Ok, thanks to both of you guys!!!!!
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Using Thevenin with Op amp. sn00py23 Homework Help 59 03-08-2010 11:05 AM
Drawing rectangle using x and y co-ordinates killer6008 Math 3 02-23-2010 09:00 AM
How do harmonics damage the line/appliance? alphacat General Electronics Chat 9 10-24-2009 09:36 PM
Complex Numbers - A Basic Introduction Nirvana Math 16 11-16-2007 04:49 AM
Homework Help choco1 Homework Help 2 05-02-2006 03:01 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
