All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-18-2010, 04:58 PM
johndoe45 johndoe45 is offline
Default testing a FET
i am testing a FET
here is spec sheet
http://forum.allaboutcircuits.com/at...0&d=1268639919
now here is what one website says.
using the diode function on your DMM.
probe with - on the drain and + on the gate. this should arm the FET.
then keep - on drain and put + on source. multimeter should beep.
my FET passed this SO FAR.
now it says to test the FET's ability to switch off touch all three pins with finger. then put - on drain and + on source again and should get a high reading.
well my FET still beeps. is the FET defective????
  #2
Old 03-18-2010, 05:01 PM
retched's Avatar
retched retched is offline
Default
Your finger could be defective.
Does your DMM have a npn or pnp test area/function?
__________________
-rm-
The Following User Says Thank You to retched For This Useful Post:
musicinhills (07-20-2013)
  #3
Old 03-18-2010, 05:03 PM
Default
lol
i don't think so
  #4
Old 03-18-2010, 05:07 PM
retched's Avatar
Default
ok, try this instead:
Quote:
Testing MOSFETs
Field Effect Transistors are difficult to test with a multimeter, but "fortunately" when a power MosFet blows, it blows big time: all their leads will show in short circuit. 99% of bad MosFets will have GS, GD and DS shorted. In other words - everything will be connected together.
Note: When measuring a MosFet hold it by the case or the tab and don't touch the metal parts of the test probes with any of the other MosFet's terminals until needed. Do not allow a MosFet to come in contact with your clothes, plastic, etc. because of the high static voltages they can generate.
You'll know a MosFet is good when the Gate has infinite resistance to both Drain and Source. Exceptions to this rule are FETs with protection circuitry - they may act like there is a diode shunting GS - a diode drop for gate reverse bias. Connecting Gate to Source should cause the Drain to Source act like a diode. Forward biasing GS with 5V and measuring DS in forward bias should yield very low ohms. In reverse bias, it will still act like a diode.
Another simple test procedure: connect the multimeter's negative lead to the source of the MosFet. Touch the MosFet's Gate with the meter's positive lead. Move the positive probe to the Drain - you should get a low reading as the MosFet's internal capacitance on the Gate has now been charged up by the meter and the device is turned-on. With the meter's positive lead still connected to the Drain, touch the source and gate with your finger. The Gate will be discharged through your finger and the reading should go high, indicating a non-conductive device! This simple test is not fail proof, but it's usually adequate.
__________________
-rm-
  #5
Old 03-18-2010, 05:08 PM
retched's Avatar
Default
If you are getting continuity between drain and source, its a gonner.
__________________
-rm-
  #6
Old 03-18-2010, 05:23 PM
Default
gate has infinite resistance to both drain and source
and no continuity between drain and source
so i'm guessing it is still good?
i don't understand this part of third paragraph
  #7
Old 03-18-2010, 05:28 PM
retched's Avatar
Default
It is still good.
The third paragraph is explaining how to test protected FETs as diodes.
No continuity, no problem. If you had continuity, then you would do a diode check. If you get the diode drop, its still good. If no diode drop, its failed shorted
__________________
-rm-
johndoe45 (03-18-2010)
  #8
Old 03-18-2010, 05:33 PM
Default
oh ok. thanks a lot. spent thirty minutes reading up on it and you helped me in only about 5 minutes.
  #9
Old 03-18-2010, 05:53 PM
retched's Avatar
Default
Any time I can help, i'll try.
__________________
-rm-
  #10
Old 03-22-2010, 08:40 PM
Default
i can't figure out if it is not switching off???
here is what i did. hold black probe at drain whole time. touch gate with red and then touch source with red while touching gate and drain with finger. a reading shows.
now to switch it off do i keep my fingers on the drain and gate???
cause i read you have to touch gate once with red and then touch source again. but doesn't specify if i keep my fingers on drain and gate.
Tags
Related Site Pages
Section Title
Worksheet Basic logic gate troubleshooting
Worksheet CMOS logic gates
Worksheet Performance-based assessments for semiconductor circuit competencies
Worksheet Insulated gate field-effect transistors
Worksheet Junction field-effect transistors
Textbook Quantum devices : Solid-state Device Theory
Textbook Insulated-gate field-effect transistors (MOSFET) : Solid-state Device Theory
Textbook Junction field-effect transistors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Logic Level Gate FET DC_Kid The Projects Forum 6 05-23-2009 02:58 PM
Single FET AC Relay - Possible Management General Electronics Chat 3 05-07-2009 06:17 AM
555CN timer - relay or FET on output? mezlo The Projects Forum 17 07-18-2008 06:26 PM
Testing Software chesart1 Programmer's Corner 2 02-11-2008 01:19 AM
Drive an fet with a 555 and a different power source/not the same one that powers fet arthur92710 General Electronics Chat 108 11-08-2007 07:51 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
