All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-18-2010, 08:23 AM
hepoul hepoul is offline
Default Flickering Led Circuit
Excuse me, but my english isn't good. I find in the WEB the following diagram, to make a led with flame effect (like a candle). In theory, this circuit makes the led flashing randomly. I did on protoboard, and don't work, the LED still "on" (no flashing).
I simulate on Multisim, and when run, the timer is broke. To prevent this, I connect pin 5 to ground. But the led still "on" (no flashing)
I need make this effect.
Can you help me? Thanks for advance.
Attach the original file for more information.
(Credits to owner)
  #2
Old 03-18-2010, 11:05 AM
AlainB's Avatar
AlainB AlainB is offline
Junior Member
Default
Be sure to have a stable power supply from the 7805 first. As it is, I would suspect that it could oscillate.
Here is the typical way of wiring it according to many datasheets:
  #3
Old 03-18-2010, 01:20 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
I agree with AlainB. In addition to the 0.1uF capacitor, the 555 timer requires an additional capacitor of at least 1uF in size. I suggest using a 0.1uF right at the output of the 78L05 and a 10uF across the power rails. Additionally, each IC should have a 0.1uF capacitor across its' power pins; metal poly preferred, ceramic are OK.
These are known as bypass capacitors. They are not shown in most schematics because it makes the schematic more difficult to understand (clutter) and bypass capacitors are always required for IC's, so it is assumed that people know to add them.
If you are using a standard transistorized 555 timer, you may need to use a 330 to 470 Ohm resistor between pin 3 and the 5v supply. This is because the output (pin 3) of the transistorized version of the 555 cannot go higher than Vcc-1.3v, which is 5v-1.3 = 3.7v. It may not be going high enough for the particular ICs that you are using to be seen as a logic 1.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
Tags
Related Site Pages
Section Title
Worksheet Oscillator circuits
Worksheet Arc flash and arc blast
Worksheet Physical effects of electricity
Textbook Circuit components : Using The spice Circuit Simulation Program
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook CMOS 555 LONG DURATION BLUE LED FLASHER : 555 Timer Circuits
Textbook CMOS 555 LONG DURATION MINIMUM PARTS RED LED FLASHER : 555 Timer Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pls help me.Need advice ridge84 Embedded Systems and Microcontrollers 4 11-29-2009 09:35 PM
Find LED current in switching circuit ShowerOf Homework Help 5 11-18-2009 12:57 PM
Help with Super White LED Dimming Circuit worlda The Projects Forum 9 11-11-2009 03:32 AM
LED on circuit board help. Godfree The Projects Forum 1 02-03-2009 04:33 AM
Needing a series-parallel combination resistor circuit calculator jasonbengiat The Projects Forum 1 03-13-2007 08:47 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
