| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#1
i am in the middle of building a ver.(v) ver. (c) 20 amp power supply.(br) i plan to use 4-2N3055's for reg. having never used this divice befor, i need to know how to wire these transistors.V+ in to? V+ out from? is there a ground used? voltage will be comming from v+ control pot. the letters B/C/E show me nothing. am using 2 LM317 for v,reg. (to-3's) a circuit diagram would be great. |
#2
Hi, for the specifications of this transistor I recomend to read the manufacturer datasheet of the component http://www.alldatasheet.com/view.jsp?Searchword=2N3055 and after that you will have a clear idea on how to use it and the meaning of the letters... In add, if you use google you could find a lot of examples on how to use it but basically is to use a serial resistor with the vreg with one pin to the base and the other pin to the emitter of the transistor with such a value that could have a tension of 0,6 or 0,7 volts when the limit current of the vreg is reached. This way you polarize the transistor and the current will flow through it.
This is one of lots of examples and different ways of doing what you want. Greets. PD: My english is awful and this is my first post... hello all and congrats for your amazing web. |
| Bookmarks |
| Tags |
| control, current, power, supply |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Power supply, current and voltage limiting | dude521 | General Electronics Chat | 13 | 04-23-2009 06:45 PM |
| LEDs, 555s, Flashers, and Light Chasers (Test) | Bill_Marsden | General Electronics Chat | 13 | 02-06-2009 07:03 PM |
| Switching power supply with a dead (0v) "low" side | FalconFour | The Projects Forum | 8 | 01-08-2009 11:37 PM |
| BJT's don't work like that | Ratch | Off-Topic | 120 | 06-29-2008 08:56 AM |
| 0-30 volts, 0-3amps Power Supply (Current Limeter) | haprow | Homework Help | 4 | 03-09-2007 06:25 AM |
