All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-17-2010, 03:48 PM
Cinek's Avatar
Cinek Cinek is offline
Junior Member
Default electronic stethoscope
My goal is to design electronic stethoscope (the mos simple one) and i have big problem. I was thinking about using about microphone connected to circuit with audio amplifier and on output i have headphones. It's gonna work? and could anyone give some hints how to design this circuit ?
Regards.
  #2
Old 03-17-2010, 06:20 PM
kobunko kobunko is offline
Default A good project for you
Quote:
Hi. I think this one is almost that you need. I hope will be good for you. Regards from Argentina.
P.S.: the web is in spanish, but I think is easy to understand the circuit.
http://www.hispavila.com/3ds/tutores/estetoscopio.htm
  #3
Old 03-17-2010, 08:16 PM
Cinek's Avatar
Junior Member
Default
ooo thanks so much btw. now i am on student's exchange in spain, so spanish is not a problem .. ;]
  #4
Old 03-17-2010, 09:52 PM
Audioguru's Avatar
Audioguru Audioguru is offline
Default
They copied my circuit but used noisy old opamps:
  #5
Old 03-17-2010, 09:59 PM
Audioguru's Avatar
Default
Quote:
EDIT:
Their date is before mine but I never saw theirs until now. So we both fixed the horrible original project a www.aaroncake.net .
They made a few changes that I should have made.
  #6
Old 04-01-2010, 10:29 AM
Cinek's Avatar
Junior Member
Default
hey, i have few questions concerning this design:
1. Why we use capacitor C1?
2. in amplifier U2 why we construct this feedback formed by C4 and R7?
3. what does C5 and R8 are doing ? (can i use as C5 two normal condensators - not eletrolytic?)
4.R11 and C7 form next filter?
5.what elements : C10, C9,R14, C11 are making ?
Thanks in advance for the answer
  #7
Old 04-01-2010, 01:48 PM
Audioguru's Avatar
Default
hey, i have few questions concerning this Spanish design:
It filters the +9V supply to prevent the +9V from jumping up and down when the LM386 power amplifier uses a fairly high current to feed a speaker or headphones.
U2 is a 2nd-order inverting lowpass filter.
C5 uses two 1.2uf polarized capacitors in series and back-to-back to make a non-polarized 0.6uf capacitor. The capacitors are not needed and can be removed.
U3, R8 and R10 do nothing and can also be removed. The volume control R11 should be 10k and C7 should be removed.
Quote:
5.what elements : C10, C9,R14, C11 are making?
C11 blocks the DC at the output of the power amplifier U5 from burning out the speaker or headphones. The other parts prevent the LM386 power amplifier from oscillating at a high frequency as shown on its datasheet.
  #8
Old 04-01-2010, 08:13 PM
Cinek's Avatar
Junior Member
Default
so we can simplify this SPANISH design to this form ?
and the last question i hope what is the job of C6 and C8 ?
  #9
Old 04-01-2010, 10:34 PM
Audioguru's Avatar
Default
so we can simplify this SPANISH design to this form?
You used two very noisy old LM324 quad opamps wasting 6 opamps and needing 28 pins.
I used a single low noise dual opamp that has only 8 pins.
Your opamps have a total gain of only 2, then you add C6 to the LM386 power amp to boost its gain 10 times so it amplifies its own noise plus the noise from your old opamps.
I used gain in both opamps so that the LM386 power amp did not need to have its gain boosted then the noise level is low.
I think the second opamp in the original Spanish circuit is wrong. Yours is a wrong copy since theirs inverts and yours is non-inverting. I have only made non-inverting Sallen and Key second-order Butterworth lowpass filters. I have never seen inverting second-order filters like the Spanish circuit. Yours has the values of its capacitors wrong (C4 should have double the value of C3) so your circuit might oscillate.
They are explained in the datasheet for the LM386.
  #10
Old 04-02-2010, 02:36 AM
Cinek's Avatar
Junior Member
Default
i read your comment, then traveled along internet to find some solutions and i changes my design to some kind of mix of both :
values in low-pass filter are calculated for cutoff frecuency of value 150 Hz , with this value my results will be satisfactory? or should i choose another value of frequency? And one more question is about total gain. Now it has 10 times higher value than in your design , isn't it a problem ?
in advance and as for now.. thank you very much for your help :-)
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
