| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#1
Looking at using an NTE5987 silicon power rectifier diode for a pedal powered generator application. It is is rated for 40 A and will prevent current from flowing from the battery back to the generator. I plan on bolting it to a heat sink. Have any idea on what the difference between an "anode-to-case" and "cathode-to-case" means.
#2
The part that is bolted down is the "to case" The tab on top is the other.
I.E. Cathode to case, the threaded part at the bottom that bolts down is the cathode. The eyelet at the top would be the anode Anode to case, the threaded part at the bottom that bolts down is the anode. The eyelet at the top is the cathode.
__________________
-rm- |
#3
Between the both of them you could have a full wave bridge rectifier.
__________________
.. "Good enough is enemy of the best." An old engineering saying, Author unknown. General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie. |
#4
is there any reason why i would want one over the other?
#5
As Bill implied - you may have a situation where you want to have several devices connected at a common node - such as at either the +ve or -ve side of a bridge rectifier comprised of discrete power diodes of this type.
#6
You would probably want to use one that can be bolted to a grounded case which would be the Anode to Case, this way you wouldn't have to isolate it from the case if it was the other way around or else you will have a direct short from + to -.
I used a Anode to Case for my Windmill generator since the charging circuit was grounded to the case and I wanted to bolt the heatsink to the case... If I would have gotten the cathode to case, I would have created a direct short from the positive coming from the generator to the grounded heatsink... ![]() B. Morse
__________________
There is no spoon -Neo- ![]() Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk! |
#7
Mind you - nowadays, with the increasing use of fully modular units such as single or poly-phase rectifier bridges, the need to think about such matters is declining.
#8
Finding a suitable nut or tap to mount the thing will drive one mad.
__________________
L.Chung |
#9
I keep a stock of 35A 1200V bridge rectifiers. For some reason these are very cheap (like $5) from several suppliers and very useful whenever a high powered rectifier or diode is needed.
They have four 1/4" push-on terminals and an isolated metal base with a single fixing hole, so they are also very easy to mount. You can use them as a 'single' diode by connecting both AC teminals together as one side and one of the DC teminals as the other. (That puts two of the bridge diodes in parallel). If you've not bought a power diode yet, have a look at what your suppliers can offer.
__________________
Robert Jenkins. |
#10
Quote:
Mine fortunately came with the nut and lock washer, and it actually uses a standard ANSI threaded tap, I believe 3/8-16 or 5/16-18 one of the 2 can't remember off the top of my head.... Quote:
B. Morse
__________________
| Bookmarks |
| Tags |
| amp, diode, mount, stud |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Experimental design for small sig. amp | hobbyist | General Electronics Chat | 50 | 07-22-2009 07:42 PM |
| Simple Op Amp & Zener Diode Questions | Student01 | Homework Help | 12 | 05-15-2009 05:50 PM |
| Does anyone KNOW HOW TO MOUNT A 150EBU02 diode | HHO-BLASTER | Embedded Systems and Microcontrollers | 2 | 05-01-2009 11:13 AM |
| Broken diode in my guitar amp? | tmac | General Electronics Chat | 7 | 10-29-2008 05:52 PM |
| Question about parallel car batteries...and amp meter usage... | kazlx | General Electronics Chat | 14 | 01-14-2008 02:29 AM |
