| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
I would like to build a breakout board for LCD panels.
One if the ones I have been buying look like the attached. Basically it is a 16 pin, what sort of looks like an edge connector but nit exactly. What I am doing currently is to solder a SIP into the connector and then connect make my various connections to that. I suppose I could use a header and a SIP. Soldering one to the breakout board and the other to the LCD panel. But I really want to avoid soldering on the LCD panel. I just want to be able to plug it in. Do these edge type connectors exist? If so what would I look for? (I will be ordering from mouser). |
#4
Quote:
I wonder if you could even get a 16pin version. And if you look at the connector a regular edge connector would not work unless maybe I modified it. You would need to knock out the two ends of the connector. |
#6
Yeah I guess but I might still need to modify it right? Or maybe if it were large enough it would work.
#8
Just use a single header row of pins, and solder it to the LCD panel connector.
Otherwise, if you try to fool around with a card edge connector, and there is no means to accurately align it, you stand a very good chance of burning up either the LCD display or whatever you're using to drive it with. You can use a ribbon cable with those snap-on connectors to drive the thing with. An old floppy disk drive cable might work OK for that - use a dual row header on your breakout panel, and ground all the pins in one of the rows. That will provide alternating signal/ground/signal in the cable to the LCD. Just make certain you align the LCD headers correctly when you plug it in.
__________________
General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. |
#9
Quote:
I'm think I'll set up my "breakout" board to mimic the type of connector I am using in my projects. That way I only solder up the LCD once. |
#10
Yeah. Thats how they all end up. After the hours of figuring what to do, you could have soldered the header on and been building.
It really is a very good way to go.
__________________
-rm- |
| Bookmarks |
| Tags |
| connector, lcd, panel |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| LCD and real clock timer | apiz88 | Programmer's Corner | 3 | 10-03-2008 05:39 AM |
