| Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help. |
Thread Tools | Display Modes |
#1
I am designing a circuit that include a LM741 as comparator that requires +Vcc -VEE from a 9V battery. Can this be accomplished using voltage divider? If so. How? If not, your suggestion.
#2
Any opamp can be biased at half the supply voltage then use a single polarity supply.
But some 741 opamps do not work with a supply voltage as low as only 9V. |
| The Following User Says Thank You to Audioguru For This Useful Post: | ||
Slik_Willie (03-31-2010) | ||
#3
All the data sheets characterize the 741 for operation at +/-15 VDC, and never for single supply. If the 741 is an anemic op amp, it is a really bad comparator. Don't know what your inputs might be, but an LM311 would offer superior operation (it is a comparator).
__________________
First comes the hardware, then the software. |
#4
I'm currently using the LM324 for my single supply applications.
__________________
Everything is relatively defined. Transistors in circuits are biased, leave our mind unbiased. |
#5
Quote:
The MC33171 single, MC33172 dual and MC33174 quad opamps have exactly the same low power but have no crossover distortion, also operate from a supply as low as 3V and have a full output up to 35kHz. Their gain is nearly 40 at 40kHz. Their inputs work at the negative supply voltage that could be 0V. Their outputs go down very close to the negative supply voltage that could be 0V. But their output high current is only 3mA to 5mA. The MC34071 single, MC34072 dual and MC34074 quad opamps also work from a single supply as low as 3V and their inputs and outputs work down to 0V. They have normal supply and output currents and a full output up to 100kHz. |
#6
Thanks for the explanation. You're the guru, so I leave it to the more knowledgeable.
__________________
#7
Thanks for the tip Guru.
#8
Quote:
to answer your question, yes there is a way you can get the +VCC and -VEE from 2 9 volt batteries to power a 741 opamp... ![]() B. Morse
__________________
There is no spoon -Neo- ![]() Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk! |
#9
Here is a simple way of generating +/- supply with a catalog coupled inductor and a integrated switching regulator.
http://focus.ti.com/general/docs/lit...Number=slva369 |
#10
Another possible way of doing it using a 1/4 of LM324. Apologies to those who would love to see the back of LM324's.
| Bookmarks |
| Tags |
| battery, lm741, power, supply |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Multiple Devices on a Single Power Supply | DanRilley | General Electronics Chat | 6 | 01-18-2010 04:14 PM |
| Using a variable power supply for charging and discharging | fastwalker | General Electronics Chat | 5 | 10-03-2009 11:21 PM |
| E-book Correction Error in Maximum Power Transfer Theorem page | Ray A. Rayburn | Feedback and Suggestions | 27 | 09-01-2009 08:53 PM |
| 7805 & 12VDC Power Supply Problem | JDC | The Projects Forum | 10 | 10-24-2008 06:09 AM |
| Convert PC Power Supply to Bench Supply | Distort10n | General Electronics Chat | 3 | 04-04-2007 12:17 PM |
