All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-12-2010, 10:53 PM
alarassi alarassi is offline
Member
Default negative voltage generator of GLCD
hello guys
i'm using a glcd on a project, JHD12864e model! when i wanted to interface the glcd to microprocessor i found out that the glcd needs a negative voltage generator on its VEE pin ( pin No.18) of -10v for the GLCD driving! this model of JHD1284e glcd doesn't have the negative generator onboard!!
i know some other types of glcd might have it onboard such as (AGM1264f glcd) but since i already bought this JHD12864e glcd and want to use it, is there any possible way to generate this -10v on the VEE pin??
attached is the datasheet for JHD12864 glcd and u can see on page9 (power supply) that there's no -10V while in last page says that i need to interface it to -10V !!
thank you
  #2
Old 03-13-2010, 01:08 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Default
Do you only have a 5v supply available? Is that the problem?
We don't know where you are, and this may make it difficult to recommend components/suppliers. It helps a great deal if you put that information in your profile. Use the "User CP" link to edit your profile. You do not have to be overly specific; country and state or province is fine.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #3
Old 03-13-2010, 07:19 AM
rjenkins rjenkins is offline
Default
There are quite a few voltage converter ICs, like SCI7661 and MAX681.
These use a charge pump system with a couple of small capacitors to produce negative and/or double voltage from the supply.
The MAX680 or MAX681 may be your best choice, that will give -10 from +5V.
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1530
__________________
Robert Jenkins.
  #4
Old 03-13-2010, 11:00 AM
Member
Default
can you guys have a look at the datasheet for JHD12864e glcd and also the one for AGM1264f glcd (power supply section and VEE fucntion )and then compare the differences between their power supplies as well as Vee function!?
i'm worried that i might misunderstand the things here and i shouldn't use voltage converter in my case!
should i use -10V voltage generator at the output of Vee or no need? if yes, is it possible by using negative voltage converter as suggested to me?
thank you
  #5
Old 03-13-2010, 11:17 AM
retched's Avatar
retched retched is offline
Default
JHD12864e.pdf:
Page 17 (last page) for Interfacing LCD Driving (Vee) '-10v' needed on pin 18.
BUT looking at the power supply diagram, they have 5v to Vdd, then a 10k Variable Resistor connected to vdd in line to Vee. So it appears, you do not need - voltage.
AND in the maximum ratings, it says you can have +.03v on Vee. So i think its nuts.
It says, single supply for voltage. So I would follow the posted power supply wiring.
It must have a negative power generator on board.
__________________
-rm-
  #6
Old 03-13-2010, 11:31 AM
Member
Default
Quote:
do u mean that it has a negative voltage generator already implemented onboard?
what made me confused was that when i looked at the power supply diagram of AGM1264f i found the -10V stated there while not stated in my glcd!
  #7
Old 03-13-2010, 11:42 AM
retched's Avatar
Default
Thats what im guessing. Following the datasheet is the way to go. And it says one wire voltage connection.
So I would do it exactly as the datasheet says:
VDD to pin 1 of the variable resistor, Vo to pin 2 (the wiper) of the variable resistor and Vee to pin 3 of the variable resistor.
__________________
-rm-
  #8
Old 03-13-2010, 05:21 PM
Member
Default
i connected the glcd and measured the voltage at pin18 and it wasn't -10V !!!
i really don't know if i shoud use -10v voltage converter on my glcd or no?
anyone has used JHD12864e glcd can answer me pls?
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Negative voltage killerfish Homework Help 5 02-14-2010 02:49 PM
Op Amp Negative Feedback vindicate General Electronics Chat 15 12-17-2009 04:20 PM
opamp current direction in e-book swty_todd General Electronics Chat 62 04-02-2009 11:18 PM
Battery question CanElec General Electronics Chat 60 01-07-2009 11:10 PM
Shorts with a negative supply relicmarks General Electronics Chat 40 04-16-2008 02:22 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
