All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-12-2010, 03:17 PM
antennaboy antennaboy is offline
Junior Member
Default batteries in series
hello forum,
a question about constant voltage batteries in series:
IF a 9 volts battery is connected via cables with some minimum resistance to a battery that is 4V (with the + terminal of one battery connected to the + terminal of the other), what would happen?
I think the 9 V battery will determine the direction of the current. Will the 4 V battery get damaged?
On the long run, would the 4 V battery break down and work like an open circuit?
If the 4 V battery was completely discharged, would the 9 V battery be able to recharge it to its maximum (4V)?
When are two batteries connected that way? Only when we need to jump start a car, or recharge one battery using the other?
thanks
antennaboy
  #2
Old 03-12-2010, 03:39 PM
Audioguru's Avatar
Audioguru Audioguru is offline
Default
I think you are confusing SERIES and PARALLEL.
To jump-start a car, batteries are always connected in Parallel, never in series.
A 9V battery does not have a constant voltage. Its voltage drops when it is loaded and as it runs down.
If you connect a 9V battery in series with a 4V battery with their + wires together then the output voltage is 9V - 4V= 5V. When one battery is completely discharged then it will become charged backwards through the load from the remaining battery.
  #3
Old 03-12-2010, 03:41 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Default
It is generally not a good idea to connect batteries of different voltages in parallel to each other. This causes very high current flow from the higher voltage battery to the lower voltage battery. If the resistance of the wiring/connections are low, power will be dissipated across the internal resistance of the battery, generating heat. This can cause the battery or batteries to rupture forcefully.
A 9v "transistor" battery has a relatively high internal resistance compared to most other battery types. It is likely to be overheated first, and destroyed.
If for some reason a battery needs to be recharged from another battery, it is a good idea to control the maximum current using a resistor or semiconductors and Ohm's Law.
Sometimes it's necessary to use "jumper cables" to charge one vehicle's battery from another. In this case, the cables are typically very large gauge wire. Both vehicles should have their engines off when connecting the cables, and the final connection should be a negative connection to some point that is away from the battery, preferably to the engine block. This is to avoid making a spark near the battery, which may be venting explosive gases.
A fully charged lead-acid battery may measure in the vicinity of 12.6v-12.9v or thereabouts depending on chemistry, construction, and internal temperature. A fully discharged battery may measure around 11.5v. Even with such a small difference in voltage, heavy current will flow from one battery to the other. However, automotive batteries are designed for such heavy currents.
After the cables are safely and securely connected, the vehicle with the good battery can be started to use the alternator to charge both batteries for a period of time.
The engine with the good battery should be turned off before the engine with the discharged battery is started. Otherwise, the alternator in the vehicle with the good battery may be damaged.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Do Batteries in Parallel Last Longer?? jonnyboy24 General Electronics Chat 1 03-22-2009 05:19 AM
Help with cushman truck, wiring batteries solution? kingcoota General Electronics Chat 2 10-29-2008 01:38 AM
I can’t go the distance Help Me General Electronics Chat 34 06-29-2008 06:39 AM
C program for sine series circuit2000 Programmer's Corner 4 04-28-2007 10:02 PM
Two sets of AA batteries suddenly drained mshuggys General Electronics Chat 6 02-01-2006 09:18 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
