All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-12-2010, 02:25 PM
theoldwizard theoldwizard is offline
Default How does it work - inverter generators
Honda, Yamaha and others now sell "inverter generators". These use a small 5-10 hp gasoline engine and output 110V (I'm certain they have European voltage generators also). The most unique feature is that the engine speed is varied as the load varies. This results in much lower fuel consumption compared the other portable generators that use a constant engine speed controlled by a mechanical governor.
My limited knowledge of electric generation is that the output voltage varies with the shaft speed.
So how do you take a varying voltage (more or less constant current) from the generator section and convert it into a constant voltage, varying current source for the load ?
A circuit would be nice, by I'm more interested in a theoretical discussion.
  #2
Old 03-12-2010, 06:32 PM
beenthere's Avatar
beenthere beenthere is offline
Default
The engine may drive the alternator through a variable speed pulley - http://www.speedselector.com/
__________________
First comes the hardware, then the software.
  #3
Old 03-12-2010, 08:32 PM
Default
Quote:
Nope. Direct drive.
  #4
Old 03-13-2010, 12:43 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Well, if the output power were being produced directly by an alternator, the motor speed would be held constant to maintain the output frequency, and the field winding would be fed current to keep the output RMS voltage stable.
Using an inverter to generate the output pseudo-sinewave (or true sinewave if they were using, say, something resembling a class D amplifier with a low-pass filter) would mean that they would just have to generate enough current to keep the output voltage up for the load. This sort of thing is done with DC-DC buck/boost converters over a fairly wide range. Of course, as the input voltage drops, more input current is required to keep a given load current stable.
The use of a stable circuit as an inverter to synthesize the output frequency eliminates certain problems, like another member posted several months back - they used a large, low RPM diesel engine to drive their generator. Unfortunately, the RPM varied significantly due to the high compression and violent power stroke, and the variation of frequency in the output power was too unstable to run a number of their motor-driven appliances. His options were fairly limited; increase engine RPM and use a reduction drive, possibly using a flexible coupling between motor and generator with a heavy flywheel on the generator, and I don't remember what all else.
Anyway, advances are being made in power generation efficiency all the time. It's a good thing, too - we're running short of fossil fuels.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #5
Old 03-13-2010, 11:46 AM
Default
Just to keep this discussion going, I'll give you my SWAG !
The alternator section uses a rare-earth magnet rotor, spinning inside a 3 phase (or maybe 5 phase) stator. Diodes convert the output of this section to DC. Here is my first "assumption" ! The windings are such that output voltage from the diodes is greater than the peak-to-peak voltage of a 120V 60Hz sine wave (> 170v) !
Next is a filter section, probably with a hefty inductor. This needs to supply the inverter section even when a load is added.
Many of these portable generators have a secondary low voltage winding for charging wet cell lead acid batteries. This is perfect for running some of the electronics.
The inverter section is based on a crystal controlled, sine wave generator (like a XR2206). This feeds a Class D MOSFET amplifier which gets it supply from the high voltage DC.
A microprocessor monitors the output voltage and then runs a stepper motor which open and closes the throttle.
  #6
Old 03-13-2010, 04:01 PM
SgtWookie's Avatar
Expert Member
Default
Yes, they could be using neodymium magnets, and it may have more than 3-phase output. Synchronous rectification would be much more efficient than a traditional rectifier bridge.
I sincerely doubt that they are using an old linear oscillator like an XR2206; much more likely that they are using something like a microcontroller that has a sinewave table in the programming, or an otherwise dedicated PWM IC. Throttle control would more likely be a servo instead of a stepper.
__________________
General info:
Tags
Related Site Pages
Section Title
Worksheet Servo motor systems
Worksheet AC generator theory
Textbook Tesla polyphase induction motors : Ac Motors
Textbook Brushless DC motor : Ac Motors
Textbook Reluctance motor : Ac Motors
Textbook Synchronous Motors : Ac Motors
Worksheet DC motor theory
Textbook Voltage regulation : Transformers
Textbook Special transformers and applications : Transformers
Textbook Automotive alternator : Ac Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
npn inverter circuit pulls up but does not pull down completely przachar General Electronics Chat 5 03-03-2010 09:07 PM
Difference between UPS and Inverter. cjdelphi General Electronics Chat 3 01-19-2010 05:37 PM
Voltage = work or force? Unregistered Feedback and Suggestions 1 12-20-2008 01:17 AM
adders don't work.. jun Homework Help 5 12-05-2008 07:21 PM
Half bridge inverter Marie The Projects Forum 2 05-15-2008 06:15 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
