| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#1
hi , and how can someone make a very powerful electric magnet , and also with small size ?
#2
size matters when it comes to electro magnets buddy....the bigger, more power required, more powerful magnet
__________________
Peace to all Rifaa __________________________________________________ _________________________________________ I am sorry to inform that I cannot accept invitations from fresh members with low post counts, as lately I am getting too many. __________________________________________________ _________________________________________ I just donno when to Give Up. ![]() |
#3
The relative strength of an electromagnet is measured by it's Ampere-Turns rating.
More turns and/or more current increase the strength. You are limited on current by how much the wire is rated for (and heat build-up within the coil), turns are only limited by size. The absolute strength also depends on the magnetic core and physical layout. Depending what you mean by 'small', you probably cannot match the strength of a small neodymium permanent magnet. Even for small industrial lifting on cranes, permanent magnets are used in preference to electromagnets.
__________________
Robert Jenkins. |
#4
Quote:
hgmjr |
#5
A very strong DC electromagnet can be made by machining a cup out of a steel billet, leaving a center pole that will accept a wire-wound bobbin.
You can experiment with various numbers of magnet-wire turns to get an idea of the strength factor, (amperes x turns). Cheers, DPW [ Everything has limitations...and I hate limitations.] |
#6
Quote:
Also, you can disassemble an old hard drive and get some mighty powerful magnets. Eric
__________________
REAL men don't need voltmeters. |
#7
Oops. Missed the Electro part.
![]() Well the info is still good, anyway. Eric
__________________
#8
thanks people ^_^ ...
#9
Ask Politely to any PC shop and get an Old, damaged Desktop HDD.
HDDs have one of the BEST EVER Rare earth magnets! These are permanent magnets, not electros. I ripped apart one and It was so hard even to get out! Actually, i thought it was glued, but! Actually the magnet itself was so strongly attached to the casing. |
| Bookmarks |
| Tags |
| magnet, strong |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| choosing a permanent magnet | samjesse | Off-Topic | 12 | 02-20-2010 12:54 AM |
| Quantification of Electrostatic Charge | junglelord | Off-Topic | 14 | 02-06-2010 07:43 PM |
| DC blocking versus AC coupling | TheBigPablo | General Electronics Chat | 21 | 11-27-2008 07:29 AM |
| Energy in a magnet | mentaaal | General Electronics Chat | 22 | 01-04-2008 03:29 AM |
