All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-11-2010, 02:03 AM
rhodes rhodes is offline
Smile sensors to find torque , speed and output power
Hi rhodes here,
I am working on a project that involves finding torque , speed and power output from a generator. and transfer the signal from the sensors to a information logger and connect to the computer to display the results.
I have found the information logger... but its been hard to find sensors requiring to measure the quantities such as speed, torque, and power output generator.couls you suggest me some circuits that perform that operation or some cheaper electronic sensors that do the job.
waiting for your reply
regards
rhodes
  #2
Old 03-11-2010, 07:34 AM
Alberto Alberto is offline
Default
Hi rhodes, welcome to the forum.
To measure speed you will need a hall effect sensor and a magnet mounted on the generator shaft. so that for every pulse given by the sensor you have one turn of the shaft.
To measure the power you will need two dimentions Voltage and current (W=VxI)
To measure the torque you will need a very expensive peace of equipment, or you can measure the current drawn by the motor driving the generator, which will be directly proportinal to the torque required by the generator.
Alberto
The Following User Says Thank You to Alberto For This Useful Post:
rhodes (03-11-2010)
  #3
Old 03-11-2010, 02:44 PM
kubeek's Avatar
kubeek kubeek is online now
Send a message via ICQ to kubeek
Default
About the torque: there are two ways to measure it: on the shaft and on the body of the motor.
On the shaft it is done by measuring the deformation of some element "in series" with the load, usually by comparing the angle of the shaft before and after the deforming element.
The other way could be easier to incorporate in the design if the generator is not too large. You just measure the force that holds the generator in place, which is proportional to gravity+torque. Less accurate, but doesn't require cutting the shaft and mounting the torque meter.
The Following User Says Thank You to kubeek For This Useful Post:
rhodes (03-11-2010)
  #4
Old 03-11-2010, 11:20 PM
Default
thanks for the information guys!
would you be able to give some sensor circuits that measure the above quantities
  #5
Old 03-11-2010, 11:36 PM
kubeek's Avatar
Default
That depends on the sensor. I have no idea how the sensor works or what is its output and sensitivity, but it should generaly be an instrumentation amplifier.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Control Motor speed and timing Tobias General Electronics Chat 1 01-07-2010 06:58 AM
Concept of slip speed in Self Excited Induction Generator (SEIG) b.shahvir Physics 4 01-03-2010 09:09 AM
Grid control or Generator Control!! sheknowsjoy General Electronics Chat 6 04-03-2009 02:30 PM
Problems with motor fans and speed controllers Electricsix General Electronics Chat 2 02-27-2009 09:42 AM
Calculating Brushless DC Motor's output Torque Terp General Electronics Chat 2 07-29-2008 10:09 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
