All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-10-2010, 03:12 PM
CircuitSurfer CircuitSurfer is offline
Junior Member
Default Power Supply for RF Modulator
Hi I need a power supply for my project. I intend to take the plug off the the phone charger but I have no multimeter to know which line is positive. One of the two wires have a white stripe running on top of it. Would that be the positive?
  #2
Old 03-10-2010, 05:13 PM
ziouranio ziouranio is offline
Junior Member
Send a message via Skype™ to ziouranio
Default
Quote:
I have experienced both cases where the white strip indicates the positive and cases where the strip is on the negative.... the only way to be sure is to use a multimeter and check.
  #3
Old 03-10-2010, 05:38 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Default
Here is a simple and cheap low voltage polarity checker you can build:
The probes can be just plain wire.
Both LEDs need to be in the circuit, as they protect each other from excessive reverse voltage.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Submission: Power Supply Circuits Bill_Marsden Feedback and Suggestions 22 05-22-2010 05:38 PM
Switching Power Supply Construction Tips radiohead General Electronics Chat 4 06-05-2009 01:22 PM
Benchtop Power Supply - Help demonGeek General Electronics Chat 8 02-27-2009 11:54 PM
7805 & 12VDC Power Supply Problem JDC The Projects Forum 10 10-24-2008 06:09 AM
Power problem...but not the power supply. BiggerBean Computing and Networks 15 05-22-2008 10:35 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
