All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-09-2010, 07:45 PM
saadia47 saadia47 is offline
Default DC-DC boost converter practical design
I have designed a boost converter (DC/DC) which steps up voltage from 12V to about 46V. I have used 1mH inductor, 220uF capacitor, and MOSFET with 16KHz switching frequency. I am using a 555 timer to generate PWM control pulses, and putting in about 75% duty cycle.
Now in next stage I have to connect it with a DC to AC inverter. The inverter is designed using a Full bridge configuration.
Now the problem comes when I connect the Boost converter whose output is 40V to feed the DC/AC inverter, and the output of the AC voltage comes about half of its input (about 20V AC). I am guessing its due to incorrect impedance match between the two circuitry.
Does anyone have some idea about this issue? If you need anymore details please ask me.
Thanks in advance
  #2
Old 03-09-2010, 09:07 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Default
Where is your schematic diagram of your circuit? You must have forgotten to attach it to your post.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Control Design for a Bidirectional Buck Boost Converter enyyubfa The Projects Forum 6 07-15-2010 01:48 AM
DC-DC Boost converter Design Maharajan.ps The Projects Forum 3 02-01-2010 09:20 AM
DC DC converter saadia47 The Projects Forum 1 11-06-2009 02:33 PM
Construction of DC to DC converter (Boost) hbklau The Projects Forum 1 11-04-2009 04:58 PM
Analog control design for a Boost converter juampac The Projects Forum 1 06-18-2009 12:56 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
