All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-08-2010, 11:30 PM
s3b4k s3b4k is offline
Junior Member
Default discrete math- sequence question
I need to come up with a rule or a formula for the following:
1,2,2,2,3,3,3,3,3,5,5,5,5,5,5,5.....
  #2
Old 03-09-2010, 12:10 AM
someonesdad someonesdad is offline
Default
Hint: 2*n + 1 and primes
  #3
Old 03-09-2010, 12:22 AM
jpanhalt jpanhalt is offline
E-book Developer
Default
There may be more than one pattern that gives that initial sequence. One solution is: the digits 1,2,3,and 5 are primes (positive). The repeat frequencies seem to follow just the odd numbers. The next three repeat frequencies would be 9, 11 and 13. That is, the next two sequences would be nine 7's, then eleven 11's.
John
The Following User Says Thank You to jpanhalt For This Useful Post:
s3b4k (03-11-2010)
  #4
Old 03-09-2010, 12:45 AM
Junior Member
Default
ok thanks a lot for the help, but is there an exact formula i can use, or is it only solvable by explaining it?
  #5
Old 03-11-2010, 12:34 PM
Markd77's Avatar
Markd77 Markd77 is offline
Default
1 isn't normally considered a prime if that makes any difference.
  #6
Old 03-11-2010, 12:48 PM
E-book Developer
Default
Sorry. Problem easily solved in the description.
http://mathworld.wolfram.com/PrimeNumber.html
John
  #7
Old 03-11-2010, 03:09 PM
Markd77's Avatar
Default
I searched for the sequence on google and found this. Still no idea what it is.
Quote:
For each of these lists of integers, provide a simple formula or rule that generates the terms of an integer sequence that begins with the given list.
(a) 3, 6, 11, 18, 27, 38, 51, 66, 83,
(b) 1, 2, 2, 2, 3, 3, 3, 3, 3, 5, 5, 5, 5, 5, 5, 5, 8, 8, 8, 8, 8, 8, 8, 8, 8,
  #8
Old 03-11-2010, 03:59 PM
E-book Developer
Default
For (b) the sequence starts with 1, and if there are at least 2 previous term, then the subsequent term is the sum of the previous two terms, otherwise it is 2 (or alternatively, the previous term is doubled). The replicates of each term is as in the first problem.
I am too tired to look at (a) now. Perhaps this question should have its own thread.
John
Edit: For (a) here's a reference: http://mathworld.wolfram.com/Near-SquarePrime.html
  #9
Old 03-11-2010, 11:19 PM
Junior Member
Default
this question is driving me nuts, are the next three terms going to be 8,8,8 or 7,7,7. because it good either be prime numbers or just the sum of the previous numbers, but if its the sum of the previous numbers how do you get the two there
  #10
Old 03-11-2010, 11:32 PM
E-book Developer
Default
Quote:
There is not enough information to know for sure. The sum of the previous numbers (Fibonacci, 8) may be what your teacher wants. In either case, you have to make an explanation for the first number (or absence thereof).
John
PS, when I went to school 1 was still prime. But then, it was a public school.
s3b4k (03-11-2010)
Tags
Related Site Pages
Section Title
Video Lecture Troubleshooting Transistor Circuits - Transistors and Transistor Circuits
Textbook Sequences : Algebra Reference
Textbook Minterm vs maxterm solution : Karnaugh Mapping
Textbook Logic simplification with Karnaugh maps : Karnaugh Mapping
Textbook Larger 5 & 6-variable Karnaugh maps : Karnaugh Mapping
Textbook Boolean arithmetic : Boolean Algebra
Textbook Quantum physics : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
I am a math rock. Simple transposition question SgtWookie Math 10 03-03-2010 06:30 PM
infrared Liquid level detector fantabulous68 Embedded Systems and Microcontrollers 49 09-27-2009 09:18 PM
Math Question! Nishki Homework Help 7 04-27-2009 03:54 PM
convergence - math question silvrstring Homework Help 3 05-28-2008 05:34 AM
discrete math and proof braddy Math 2 09-09-2006 03:56 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
