how can i check series of a diodes
beenthere
Joined Apr 20, 2004
15,819
Use a meter. If it has a PN junction check function, use that. Shorted and open diodes will be easy to spot. Forward conduction drops should be very similar for the same type of diode.
SgtWookie
Joined Jul 17, 2007
22,230
Pass a voltage-limited controlled current through the diodes wired in series, around 20mA.
Each diode will drop a certain voltage across itself, depending upon the diodes used and the current.
If the sum of the voltage drops is in the expected range, then it's likely that the diodes are all good.
If the voltage is at the limit, one or more diodes are open.
If the voltage is less than expected, one or more diodes are shorted.
