Square Wave Generator
marims
Joined Jan 27, 2008
15
Hi
I m working on a waveform generator using AD9833, Outputs three types
Square , Sine and Triangular. The sq wave output is a fixed 5V with programmable (Variable) frequency.
But, what I need is a Variable Voltage Square wave output ( 0.5V to 5V ) up to 1 MHZ.
Please suggest.
Marims
russ_hensel
Joined Jan 11, 2009
825
Run the signal thru a op amp unity gain voltage follower with an attenuator on the input. Make sure the amp is fast enough to not round the signal ( 10 meg hz or more ).
This is on the fast side for op amps, but should work.
SgtWookie
Joined Jul 17, 2007
22,230
Russ, you're on the right track, but an even faster opamp is required. A square wave is the sum of all the odd harmonics of the fundamental frequency.
