All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Closed Thread   Post New Thread
Thread Tools Display Modes
  #1
Old 03-06-2010, 05:07 PM
SeeMyProfile SeeMyProfile is offline
Question Power little LED with 110 Volt
I'm 60 years old but never will be too old to learn.
I have a project where I'd like to use a small LED to indicate that there is power (110 volt AC).
The light and resistor would be encased in a plastic resin compound which would hinder the removal of heat from the resistor, if any. I don't want a huge resistor in the circuit, a little one would be fine.
Are there small LED's on the market designed for use at 110 Volt? If so, I can't find them.
Could I use a small resistor in line before the LED so this little 1.5 volt LED wouldn't burn out? Is that possible?
Sure could use some specific help here.
Robb in Grand Rapids, Michigan
  #2
Old 03-06-2010, 05:51 PM
beenthere's Avatar
beenthere beenthere is offline
Default
What is a better choice for a pilot lamp is a neon indicator - http://parts.digikey.com/1/parts/680...e-1033qd5.html
http://parts.digikey.com/1/parts/680...d-1031qd1.html
LED's are DC devices only, and used in low voltage applications.
__________________
First comes the hardware, then the software.
  #3
Old 03-07-2010, 01:39 PM
Mike33 Mike33 is offline
Default
+1 You can even get them at Radio Shack; they're replaceable if burned out, easy to wire up a socket...they have advantages over the LED.
  #4
Old 03-07-2010, 03:59 PM
eblc1388's Avatar
eblc1388 eblc1388 is offline
Default
Quote:
Yes, you can. But for AC usage a diode is required otherwise the LED will be damaged. Just about any diode like the 1N4148 can do.
Just use a resistor of 100KΩ in series(roughly 1KΩ per volt) with the LED and a small diode in parallel. You would need to use "high efficiency" LED for this to work.
So all together three components. As shown below.
__________________
L.Chung
Last edited by bertus; 11-09-2013 at 07:57 PM. Reason: removed dangerous circuit that violates the ToS
  #5
Old 04-08-2013, 02:06 AM
phillipbeynon phillipbeynon is offline
Default
The circuit can be very simple as there are several practical methods of design.
I would suggest an NPN FET in series with an LED and gated with a resistor. That is 3 components. Any led can be used here. the important part is the amperage. Most LEDs require 20mA DC. Start by using very high resistors between the gate and negative lead of the LED and work it down until your meter across the LED reads 20ma.
(Optional) Add a polar capacitor across the LED so it doesn't blink noticeably and 30hz
Two advantages of this circuit is that you are controlling the amperage not the voltage and using a FET which reduces heat and it works for nearly all LEDs.
  #6
Old 04-08-2013, 02:10 AM
spinnaker's Avatar
spinnaker spinnaker is offline
Default
Why are you answering a thread that is three years old? Chances are the OP has solved the issue by now.
__________________
Please start sentences with a capital letter and end them with a punctuation mark. It makes your post easier to read.
  #7
Old 04-08-2013, 02:17 AM
t_n_k t_n_k is offline
Default
More importantly LED to mains is a restricted topic.
  #8
Old 04-08-2013, 02:26 AM
#12's Avatar
#12 #12 is offline
Default
Hang on! This is a necropost, second one today.
Reported.
__________________
It's only my opinion, and sometimes I'm wrong.
(I learn something almost every day on this site.)
  #9
Old 04-08-2013, 02:37 AM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
I have send the new user a PM, I am closing this thread since it violates our ToS.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
Tags
Related Site Pages
Section Title
Worksheet Precise diode circuits
Worksheet Clipper and clamper circuits
Worksheet Basic AC-DC power supplies
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Worksheet Series DC circuits
Textbook 3-bit binary counter : Digital Integrated Circuits
Textbook Biasing techniques : Bipolar Junction Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Zener diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
9v to 3.5v regulation for Power LED steed General Electronics Chat 3 02-16-2010 04:09 PM
CMOS 555 Long Duration Minimum Parts Red LED Flasher Bill_Marsden Feedback and Suggestions 3 07-22-2009 01:03 PM
High power LED driver with brightness control harsha.ub The Projects Forum 7 05-27-2009 11:06 PM
Very stable power supply from USB to UV LED smilem The Projects Forum 53 04-26-2009 07:04 AM
110 Led Bulb/Special Switch problem fboisseau The Projects Forum 0 04-23-2009 03:44 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
