All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Programmer's Corner
Notices
Programmer's Corner Discussion forum for all aspects of programming and software engineering. Any software programming language welcome: C, C++, C#, Fortran, Java, Matlab, etc.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-06-2010, 08:03 AM
Kudzie06 Kudzie06 is offline
Default sin(x) = x - x3/3! + x5/5! - x7/7!.... c programming
can anyone give me a clue On this C programming solution. I am not getting an out put.
#include <stdio.h>
#include <math.h>
//#include "stdafx.h"
int factorial (int);
int main ()
int n, m;
float x,sinx;
printf("input a value for x :");
scanf_s("%f",&x);
//comp_op=sin((double)x);
//printf("computer value: %f",comp_op);
n=1;
sinx=0;
while (n<=4);
n =pow(-1,(n-1)*pow(x,(2*(n-1)+1))/factorial(2*(n-1)+1));
sinx +=n;
printf("sin%f=%f",x, sin(x));
//scanf_s("%f",&x); return 0;
int factorial(int n);
int factorial=1;
while(n>0)
factorial*=n;
n--;
return factorial;
Thank you
  #2
Old 03-06-2010, 12:17 PM
rjenkins rjenkins is offline
Default
I'd do it incrementally at each stage, eg.
x^3 to x^5 to x^7; at each stage multiply by x squared (which you pre-calculate).
3! to 5! to 7!; at each stage multiply by two steps of an encrementing sequence, like
f *= fact++; From 3! to 5! it would start at 4, so you do *4 then *5.
f *= fact++;
Next loop, you would get *6 then *7 to go from 5! to 7!
I assume you are doing this as an excercise rather than calculating a sine for use in a program?
__________________
Robert Jenkins.
  #3
Old 03-06-2010, 05:30 PM
Ele Ele is offline
Default
//Just modified your code a bit, try this and see what happens, just
// set the + or - for your 3^ 5^ or 7^: 'Clean up the code after you see
//what happens, or you see where it went wrong for you'
#include <cstdlib>
#include <iostream>
#include <stdio.h>
#include <math.h>
using namespace std;
int factorial(int a);
int n,b;
int lngFract[20];
int main(){
system("PAUSE");
int m,i,j;
float z,y,x,sinx;
scanf("%f",&x);
printf("d= %f",x);
system("PAUSE");
b=1;
n=1;
j=3;
m=2;
i=1;
sinx=0;
while (i<5){
if (i == 1)
sinx = sinx + x;
else
z = pow(x,m + 1);
//printf("x= %f",z);
n = factorial(j);
//printf("n= %d",n);
y = z/n;
//printf("y= %f",y);
m = m + 2;
j = j + 2;
sinx = sinx + y;
//printf("sin%f=%f",x, sin(x));
++i;
system("PAUSE");
return EXIT_SUCCESS;
//printf("d= %d",n);
if (b==1)
n =a;
lngFract[b-1] = a;
b++;
else
lngFract[b-1] = a;
n = lngFract[b-1] * n;
b++;
if (a > 1)
factorial (a-1);
b=1;
return n;
The Following User Says Thank You to Ele For This Useful Post:
Kudzie06 (03-06-2010)
  #4
Old 03-06-2010, 09:41 PM
Default
Thank you so much.really appreciate.
  #5
Old 03-22-2010, 12:07 PM
goshanoob goshanoob is offline
Default
Can I see this program, but on Visual Basic, please?
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
