| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#1
Can this be done?? I am wiring a system that constant burns and flashes a light, and depending on settings power comes from either wire...
So, is there a way to do it, or am I stuck running an incandescent? 12v System btw |
#2
You can use a full-wave bridge, or two LEDs back-to-back.
With the full-wave bridge, you can use a cap to keep the supply voltage more constant. Either way, you will need to use a regulated current supply or resistors to keep the current through the LEDs under control. How many LEDs were you planning on driving? And what are their specifications?
__________________
General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Last edited by SgtWookie; 03-04-2010 at 11:39 PM. |
| The Following User Says Thank You to SgtWookie For This Useful Post: | ||
Holder350 (03-05-2010) | ||
#3
Just driving one....Actually a turn signal.....wave rectifier may be my only option.....no way to mount another LED
#4
Oh, I thought you had a 2-wire AC input.
A fullwave bridge probably won't work for your application. Since changing vehicle lighting may violate laws in various areas, we don't help people with that kind of thing anymore. There's no way we can be assured that modifications you make will still be within applicable regulations and manufacturer's specifications. This IS a safety issue - yours, and the people on the road with you. My only recommendation is that you keep the vehicle lighting exactly as how it came from the manufacturer, as it was approved by the appropriate regulating authorities.
__________________
General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. |
#5
I am complying with all local laws, thus the reason I am trying to get this to work.....
All parts are DOT approved, the way its wired sucks...I am almost sure that a full wave bridge will work, it will work just like the flip flop poles of AC current, just not quite as fast. Thanks for all the help! |
#6
Many older vehicles have lamps with two filaments; one is for parking/running lights, and the other for turn signal/brake lights.
The body of the base of the bulb is grounded. There are two contacts on the base of the bulb. If you change the bulb from incandescent to an LED, it will draw a different amount of current, and the flasher will likely no longer flash. I thought you were dealing with a low voltage AC system, not two different DC lines and a ground. In any event, you haven't described how it is currently wired very well, so it's going to be difficult to help you. I don't know what's wrong with just staying with incandescent bulbs - they last for several years at least.
__________________
| Bookmarks |
| Tags |
| backward, forward, leds, run, wiring |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 75 LEDs installed on a medallion | flipper80 | The Projects Forum | 47 | 02-28-2010 03:13 PM |
| Help on wiring LED's | luke123 | General Electronics Chat | 24 | 02-12-2010 02:52 AM |
| Wiring multiple leds together in tail lights | lbjallday | General Electronics Chat | 7 | 01-26-2010 04:55 PM |
| LED's and power to run | B.A. Klim | The Projects Forum | 5 | 03-30-2009 02:51 AM |
| LEDs, 555s, Flashers, and Light Chasers (Test) | Bill_Marsden | General Electronics Chat | 13 | 02-06-2009 07:03 PM |
