All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-01-2010, 08:02 PM
MattATI MattATI is offline
Question Help hooking up "open drain" output
Ok, here is my issue. I have a electric motor. Motor has some I/O build in.
Here are the functions:
1. Pot +
2. Signal Common
3. Pot -
4. Vc
5. Enable
6. Direction
7. Reset
8. Fault
9. Speed monitor
These are all the connections on the motor pinout.
I need to be able to use FAULT signal and energize coil to show the condition when motor stalls or the supply voltage is too low.
The output line (OPEN DRAIN) will go low when drive is experiencing fault condition. When the drive is operational, this output can be pulled high.
I am confused on how should I hook everything up to work right.
Essentially I need to have this line (FAULT) turn on or off coil inside of the relay.
Any help appreciated
  #2
Old 03-01-2010, 08:27 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Default
I know you tried to supply a fair amount of information, but the posted info raises many questions. Do you have the datasheet for the motor, or at least a manufacturer and part number?
You say "energize coil" - I suppose you're talking about a relay that is separate from the motor.
An "open drain" is referring to a MOSFET that can sink current, but cannot source current. You could use such an open drain to sink current from a relay's coil, depending on the ratings of the open drain output, type/ratings of relay, etc. The relay would likely be used to open the coil circuit of another "latched" relay to prevent the circuit from powering up until the problem was manually corrected.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #3
Old 03-01-2010, 09:08 PM
Default
Well ,the motor is an MCG motor MA34236.
Its a brushless motor with 110Vac input to drive the motor and control lines I've mentioned on a separate cable.
Here is the link
https://servo2go.com/product.php?ID=102189
Yes, the coils I want to energize is external - its mounted in my control cabinet.
Thank you for all your help,
  #4
Old 03-01-2010, 09:29 PM
SgtWookie's Avatar
Default
Do you know that they have a technical support group?
http://www.ametektip.com/
Links to tech support are on that page.
There is not enough information supplied in the installation manual to determine what the rating (current and voltage) of this open-collector output is. Your supply for the coil would need to share a common with the motor, but it can't be determined from the installation manual whether signal ground or earth ground is what is common to the open-drain fault output.
Rather than risking damage by connecting it up incorrectly, you should contact their technical support, explain what you wish to do, and they should be able to tell you the best way to accomplish it.
__________________
General info:
  #5
Old 03-02-2010, 09:38 AM
rjenkins rjenkins is offline
Default
The data sheets are not very helpful.
One thing I noticed is a warning that the signal cables are LIVE to the AC supply and the entire control circuit must be isolated from ground.
See the warning at the bottom of Page 9 of the MA34000 data.
I think you would have to use something like an opto isolator or solid state relay with a *very* low 'coil' current, that would work using the Pot 5V supply as a power source, so the whole circuit is isolated.
__________________
Robert Jenkins.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
uC output to control bipolar transistor switching ke5nnt Embedded Systems and Microcontrollers 3 10-11-2009 09:08 PM
Negative output clock generator help... liquidair The Projects Forum 9 10-06-2009 12:56 AM
4 bit binary signal to select one of 4 different ref V to output elRey General Electronics Chat 2 02-27-2009 02:26 AM
Question : LC filter in switching power supply binvic General Electronics Chat 12 05-10-2007 01:51 AM
Encoder 16bit output Wai Programmer's Corner 4 01-19-2005 02:19 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
