All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-01-2010, 04:20 PM
charan0202 charan0202 is offline
Unhappy How to generate three phase sin wave
sir can any body tell mee how to control three phase sin voltage using single varaic . my aim is to generate 50hz 15 v three phase whose magnitude can be varied between 0-15v please help me
  #2
Old 03-01-2010, 05:13 PM
beenthere's Avatar
beenthere beenthere is offline
Super Moderator
Default
While there are three phase variacs available - http://www.stacoenergy.com/variable_...tm#GangedUnits - they are an expensive and unsafe method.
What is your application? How much power is required?
__________________
First comes the hardware, then the software.
  #3
Old 03-01-2010, 09:50 PM
t_n_k t_n_k is offline
Default
Could be done safely electronically say, using a phase-locked loop locked to a low voltage single phase 50Hz input. A 'crude' 3-phase generation could be done within the loop using a 3-stage Johnson counter. The 3-phase square waves could be filtered to produce a reasonable sine wave in each case. Amplitude control could probably be accomplished using an appropriate technique - the trick being to do it concurrently for all three phases.
  #4
Old 03-02-2010, 08:47 AM
eblc1388's Avatar
eblc1388 eblc1388 is offline
Default
Three-phase variac + three mains/15V transformers(or one three-phase transformer).
__________________
L.Chung
  #5
Old 03-02-2010, 09:24 AM
t06afre's Avatar
t06afre t06afre is online now
Default
For a education demo. I once used Labview, sound card, and a external amplifier. Just then I was writing this the idea of using a allpass filter (Google it) came to me. After some fine tuning it may work for you(or not). But it is easy test on bread board
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help with 3 phase and 6 phase half wave rectifier darthfader Homework Help 1 12-19-2009 07:01 AM
How to generate 3 sin. waves having phase difference of 120 deg leoxdragon The Projects Forum 4 06-04-2009 06:11 PM
Building a 3 Phase Sine wave inverter Celcius1 The Projects Forum 6 04-01-2009 08:15 PM
convert sin wave (withe dc level) to square wave ? pro111 General Electronics Chat 6 03-04-2007 10:21 AM
Power Engineering Help (Star-Delta) mksa Homework Help 2 05-09-2006 05:41 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
