All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-01-2010, 08:12 AM
MaxSmoke MaxSmoke is offline
Junior Member
Arrow USB to Ethernet Wiring Diagram
Hello, does anyone know or know of a source of a wiring diagram for USB to Ethernet?
You can buy just a cable and I have ordered one, but that will take a while to arrive and it would be useful to know if there is a standard for connecting USB to RJ45.
__________________
The information I provide or post on this website is for educational purposes only. By copying any information posted by me, you agree to the "as is nature of the information". No liability or warranty is given or implied. Working with electrical circuits can be hazardous and is potentially lethal. Proceed at your own risk!
  #2
Old 03-01-2010, 08:15 AM
kubeek's Avatar
kubeek kubeek is online now
Send a message via ICQ to kubeek
Default
There is no way to do it simple. You need some kind of microprocessor to act as the USB ethernet extension and then convert the data between usb and ethernet, which are two completely different protocols.
  #3
Old 03-01-2010, 08:24 AM
Junior Member
Default
Hi Kubeek, thanks for the reply. Yes, I do realise that USB and Ethernet are completely different protocols and interface standards. However, there are cables / connector sub-assemblys that allow direct connection of USB to RJ45. See this link ...
USB<>RJ45
What I am currently doing to save space, is using a USB connector to send and receive 100BaseT. I need a connector like this to translate it to a CAT5 cable.
__________________
  #4
Old 03-02-2010, 06:46 PM
kubeek's Avatar
Default
100baseT should be possible using USB connectors, but the wiring quite depends on you. If you buy that adaptor, I think you need to test which wire goes where to see the wiring. The usb connector doesnīt force you to do it any one way.
  #5
Old 03-03-2010, 12:57 PM
Junior Member
Default
Yes, I think the USB connector is cable of the data rate, so that is why I chose to use it, being much smaller than the RJ45. However, I do not think I phrased my original question very well at all. What I am trying to find is a wiring diagram of the USB to RJ45 interface connector. However, I shall know soon as I have one on order. Just thought that it might have been standardised and documented somewhere!
__________________
  #6
Old 03-03-2010, 02:18 PM
kubeek's Avatar
Default
I think the connector is meant to provide USB over cat5 wires, so you could even end up needing some other rewiring to get the right Ethernet signals to the USB connector pins.
Anyway this kind of adaptor is so strange that I donīt think there is any standard way of wiring it up.
  #7
Old 03-11-2010, 05:52 AM
dataman19 dataman19 is offline
Member
Default
I have only one question::
Does USB Require a crossover cable (like Ethernet)?
If not..
Just wire the TX pair on USB to TX pair on RJ-45 and the RX pairs as well...
Oops.. I mean the TX (+) and RX(+)... I guess you would have to tie the TX (-) and RX (-) to each other, and connect them to the USB ground...
I buy my USB to RJ-45 Connectors... never give it much tought either...
They only cost us like $3.00 each - heck an RJ-45 In-Line connector costs like $6.00 so this is peanuts cost wise..
Dataman19
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wiring Diagram for a old 3 phase starter Hawaiian Crooner General Electronics Chat 0 02-19-2010 04:19 AM
Help decoding Wiring Diagram pbalien73 The Projects Forum 12 05-29-2009 09:46 PM
iso wiring diagram Texandiablo General Electronics Chat 0 05-18-2009 07:07 PM
Wiring Diagram For my Boat Project vzaia86 The Projects Forum 2 11-17-2008 04:35 PM
Looking for PIC Family USB Bootloader Schematic Diagram. EnginiusXIII Embedded Systems and Microcontrollers 3 11-06-2007 12:24 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
