Hey everyone. I'm kind of new to electronics, just started a couple months ago but I'm enjoying it. Anyways I'm working on a circuit that needs a steady supply of 6v and when it's done I expect it to draw about 1.1A. I got a 7806 regulator which, according to the datasheet can supply about 1A when heatsinked (Or was that 1.5A?).
I'd like to be on the safe side and not run it over spec. The datasheet says you can build a circuit with a pass transistor to allow more current but the type you need is PNP. I don't have any pnp transistors but I do have a bunch of NPN power transistors (and a couple N-type Mosfets). Is there a way of building an equivalent circuit with an npn transistor? There's not much in the way of electronics stores here so I'd have to order a pnp transistor online and Id rather just use what I have.
Anyone done this before?
