All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-25-2010, 12:46 AM
spinnaker spinnaker is offline
Default First time failure: Toner Transfer Method
I tried the toner transfer method tonight. It failed. It transferred about 2/3 fairly well. In the remaining, half of that was spotty while the rest did not transfer at all.
I prepared the board by buffing it with steel wool.
Should I have Scotch Brite pads?
Now that I did a search, I know what they are. I now realize I have some. I am such a bachelor.
I then cleaned the board vigorously with acetone.
I printed the PCB layout on a page from a 2009 calendar. It has a glossy surface and I figured it was a good choice.
One thing, there was a delay of about an hour or so from when I printed the PCB to when I started to iron.
Should I start ironing right after printing?
I gave moderated pressure over all and then started moving the iron around.
I did not actually use the very tip of the iron but did lift it up on edge to apply a bit more pressure.
I ironed for about 5-10 minutes. I really should have timed it.
Where did I go wrong? Can I expect a failure the first coupe of times?
  #2
Old 02-25-2010, 12:48 AM
retched's Avatar
retched retched is offline
Default
Never want to use steel wool. Leaves particles behind, no matter how hard you try to get rid of them, and they will rust and hinder adhesion of the toner. (As you now see) And your paper choice was an unfortunate bad choice. Grab a Best Buy circular. (Or any thin gloss type ad). The "glossy" paper is a variety of layers that leaves much to be desired.
What temperature did you set the iron to? Did you LEAN into it pretty hard? Did you have the steam off?(I hope)
__________________
-rm-
  #3
Old 02-25-2010, 12:56 AM
Default
I think I see one problem. Looks like my printer was not set to highest quality by default. And dithering was on. PCB Express does not let you set printer properties!!!
Looks like I will need to print to a PDF then print using Adobe Reader. Or set my defaults tot he highest quality in control panel.
I wish PCB Express would let you set print properties .
  #4
Old 02-25-2010, 12:57 AM
Default
Is that copper toast? or can I save it?
Steam Off.
Cotton Setting.
No I did not lean real hard. I read you can sometimes press too hard and smear it.
  #5
Old 02-25-2010, 01:02 AM
BMorse's Avatar
BMorse BMorse is offline
Default
Quote:
Put some butter on it and save it for breakfast...
You can set your printer properties yourself by going to your printers folder in the control panel or in the printers folder from the start menu.......
only if you let the paper slide on the copper while ironing...... and keep the Iron flat on the piece, do not tilt it to the side or use the tip to rub it, you need to apply firm even pressure as you iron it, and you can't "over iron" it, if you are unsure, keep ironing it until you feel it is done and you feel it is sufficient.....
__________________
There is no spoon -Neo-
Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk!
  #6
Old 02-25-2010, 01:04 AM
Default
Yeah that is what I meant by going to the control panel.
Seriously, should I even bother with that piece of copper any more?
  #7
Old 02-25-2010, 01:09 AM
BMorse's Avatar
Default
Well as Retched said, you pretty much embedded it with small steel wool particles, which will rust and cause problems later on with your circuit, and the toner transfer will most likely not take no matter how you iron it. I would start with a fresh board, save that one for another use later, maybe you can use it to do a "manhattan" style pcb later on.....
__________________
  #8
Old 02-25-2010, 01:14 AM
Default
Thanks for the tips you two.
One last question. Some say to preheat the cooper before placing the paper and others say don't. What is the best way?
Oh also read a tip to use a dowel rod when ironing, Supposedly, it bends the copper a bit, giving a better transfer.
  #9
Old 02-25-2010, 01:26 AM
BMorse's Avatar
Default
I have done it both ways, and I do never really seen a difference on how it comes out, so pre heat or not to pre heat, is really up to you.
As for the dowel technique, I have heard of people using that technique, where they place a dowel under the PCB and roll over it, but to me it seems more of a hassle trying to move the iron around on the PCB as you "roll" the PCB on the dowel, it is like patting the top of your head and rubbing your belly at the same time.....
I always just used a bath towel (or similar, those thick ones) and folded that in half, and then in half again and layed that over the counter and that is what I ironed my boards on... the towel acts as an automatic leveler for the board as long as you apply firm pressure with the flat side of the iron as you move it about the board while ironing.
__________________
  #10
Old 02-25-2010, 01:59 AM
retched's Avatar
Default
As for preheating, I would wait to try it. If you preheat too warm, when you go to set the transfer, it may stick if it touches before you get it positioned properly. I never have preheated, seems to me, the iron will heat it plenty.
And about the pressure, for super thin traces, (less than 1mil) you can "smash" them a little wide, supposedly. I never print that small. But I have also heard that hard pressure can help alleviate or close pinholes. I would prefer that.
Keep that steel wool far, far away. In a distant galaxy...nevermind
__________________
-rm-
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
First PCB board which DIY method? Using Kinkos, Staples etc. ? spinnaker General Electronics Chat 45 04-27-2010 03:12 PM
PCB Toner transfer method and HP LaserJet printers tekinzen General Electronics Chat 9 11-30-2009 05:29 AM
Toner transfer BCB etching help OuZo The Projects Forum 1 01-13-2009 02:17 PM
Calculating 3db freq. using open-circuit time constant method Steve| Homework Help 2 11-12-2008 01:19 AM
Toner transfer Lt762x39 General Electronics Chat 8 09-22-2008 09:08 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
