| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
I want to make this little amplifier: http://runoffgroove.com/ruby.html However, I added an LED indicating power on and I also would like to be able to connect it to external power supply (transformer) instead of a 9V battery. The transformer I have here is rated for 9V and 500mA. Should I have further precautions with this circuit? http://i195.photobucket.com/albums/z...dae/cicuit.jpg I didn't find in J201 datasheet an absolute maximum value for drain-source current. Isn't it important? Thanks in advance for your attention! |
#2
Make sure your Wall-Wart is "rectified", and "filtered"; better yet, get one that is "regulated". If it isn't, you will have "hum", and you might end up having to add a voltage regulator like an LM317.
__________________
Mike ML |
#3
The wall wart should be fine, but many do not produce the voltage/current as per spec. Check voltage with volt meter, nice to look at output with scope for noise and ripple. If you get a lot of hum from your circuit it is probably from the wall wart, check by replacing with a battery.
| Bookmarks |
| Tags |
| questions, supply |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| More Bench power supply questions | spinnaker | General Electronics Chat | 9 | 12-10-2009 11:13 PM |
| Power supply design questions. | dswartz2 | The Projects Forum | 7 | 05-21-2009 08:08 AM |
| Power Supply Filter Question(s) | DC_Kid | The Projects Forum | 5 | 05-19-2009 12:52 AM |
| 120V AC to 12V DC power supply questions | slisgrinder | The Projects Forum | 2 | 05-14-2009 01:33 AM |
| power supply filtering questions | msoof | General Electronics Chat | 2 | 05-29-2008 05:40 AM |
