All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-24-2010, 01:55 PM
Volt Volt is offline
Junior Member
Question Butterworth Filter Sallen Ket Cut Off Frequency?
I am having a little trouble calculating the upper cut off frequency of this Butterworth Filter in the Sallen and key configuration.
Below you can see the component values in the pic:
http://twitpic.com/152zmr
The upper cut off frequency here (according to my supervisors) is 28kHZ,
however using the equation I found:
fc=1/2pi(root(R1R2C1C2))
,it doesn't equal 28kHz, I am getting 44.209kHz?!
Am I using the wrong equation?
Any help would be much appreciated,
Regards,
Adam
  #2
Old 02-24-2010, 02:03 PM
ericgibbs ericgibbs is offline
Default
hi, Look at this link: Filter Pro from TI. freeware.
http://focus.ti.com/docs/toolsw/fold...filterpro.html
  #3
Old 02-24-2010, 02:40 PM
Junior Member
Default
I'm on a mac i'm afraid
  #4
Old 02-24-2010, 03:05 PM
nubcookie nubcookie is offline
Default
here try this link
http://focus.ti.com/lit/ml/sloa088/sloa088.pdf
its quite comprehensive but try page 15 you should be able to change those equations to get the cut off frequency
  #5
Old 02-24-2010, 03:32 PM
Ron H's Avatar
Ron H Ron H is offline
Default
1. That is a filter, but it is not a Butterworth filter. You can't make a unity gain Butterworth with equal valued resistors and equal valued capacitors.
2. Stray capacitance will cause the actual cutoff frequency to differ from the calculated value. You should use higher capacitance values.
  #6
Old 02-24-2010, 03:33 PM
Jony130 Jony130 is offline
Default
Well, your supervisors is wrong.
Because IF R1=R2 and C1 = C2 the
Fo=1/(2*pi*RC)=0.16/(RC)=44KHz
  #7
Old 02-24-2010, 03:57 PM
msr msr is offline
Junior Member
Default
Did you already take a look at wikipedia?
http://en.wikipedia.org/wiki/Sallen%...93Key_topology
I find it very well explained.
  #8
Old 02-24-2010, 04:27 PM
Junior Member
Default
When I simulate this on multisim it comes out as 28kHz, is there an equation I could use to determine that value?
I have tried v hard to work it out but can't!
Thanks for all your help so far...
  #9
Old 02-24-2010, 04:46 PM
Ron H's Avatar
Default
The cutoff frequency is indeed 44kHz, but that equation does not refer to the -3dB frequency. It is the natural frequency of the filter. The gain at that frequency is equal to the Q of the filter. A Butterworth filter has a Q of 1/√2. The OP's filter has a Q of 0.5. Therefore, the Butterworth is 3dB down at the natural frequency. The OP's filter is 6dB down at the natural frequency.
A simulation of the OP's filter and a B'worth shows that the OP's filter is in fact 3dB down at 28kHz, which I'm sure can (and probably will) be calculated by another member of the forum.
A filter with higher Q will have less loss at the natural frequency, and in fact will have peaking as the Q increases.
See the Wikipedia entry for Sallen & Key.
  #10
Old 02-24-2010, 07:05 PM
Darren Holdstock Darren Holdstock is offline
Default
Just to say, all hail Ron H, this is filter gold. In one clear and concise paragraph Ron H has explained it beautifully.
I blew out a job interview at TAG McLaren Audio many years ago by asking the technical director a similar question regarding damping and the various resonant frequencies, as I couldn't find any textbook that would explain it to my satisfaction. He didn't know either, and took his revenge for my impudence in asking. Still, I learned not to ask awkward questions at interviews, lest a thirst for knowledge be mistaken for being awkward.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Butterworth filter transfer function calculation mentaaal General Electronics Chat 9 03-27-2009 04:54 PM
Need help with sallen key bandpass filter alialiali Homework Help 31 03-16-2009 07:10 PM
Sallen Key filter with different pole frequency? smokey General Electronics Chat 1 08-15-2008 12:17 AM
How to implement an Upper Cut Off Frequency? Denny1234 Homework Help 4 04-18-2008 01:50 PM
Filter Design low pass passive filter. saint_jay77 General Electronics Chat 1 08-03-2007 07:37 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
