| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
I have an ac adapter wiring problem, there are three black wires, one is solid black, the other one has a solid white line, and the third one has white dashes on it. Can anyone helpe me and tell which is the power, negative and ground? or what they are.
#3
ad adapter to my western digital hard drive with the end being a 5pin plug.
#4
Why don't you measure the wires with a $5.00 multimeter??
#5
because I'm a newbie, just came across this board by accident. I need to replace the tip and I have the tip cut off from another adapter that broke on me also but I desperately need the files from my hard drive. I need to know how to match the wires, the wires from the original adapter are different colors.
#6
If you connect the wrong polarity then the hard drive might blow up. A cheap multimeter will show the polarity if the original adapter still works.
#7
Yes, you WILL need at least a multimeter. Especially in a laptop, it you wire it backward, you have zero room for things to heat up.
And, ill ask one more time, is there any numbers, on the ac adapter? How about the model number of the Western Digital? These things matter. Alot.
__________________
-rm- |
#8
its this model number AcBel AD6008 AC / DC
Adapter Type: Device power supply Input Voltage: 100-240VAC (50-60Hz) Output Voltage: 12V and 5V Volts DC Amperage: 1.5 A and 2.5A Amps |
#9
OK.. good news and bad. You are pretty much screwed with the power supply:
read this: http://forums.computershopper.com/showthread.php?t=6010 But you can take the hard drive out of the case and put it in the computer, and the computer will power it and recognize it so you can copy every thing over. Read this: http://www.rustylime.com/show_article.php?id=1189 It is a store for the hard drive, but read the comments below, go till you see CLARK. He has the same problem as you and installed it in his tower to get his files off. If you put the 12v to the 5v side, you kill it. But if you open it up, it is the same connector as the internal hard drive
__________________
-rm- |
#10
ok the first one was fried, but then I have a new power supply then one of the pins broke off. So I have one good power supply and one good tip from another one. I need to connect the two, so that is why I need to know the wires from the power supply as to what they to connect them to the new 5 pin end.
| Bookmarks |
| Tags |
| adapter, question, wiring |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| ad adapter wiring question | Unregistered | Feedback and Suggestions | 1 | 02-23-2010 03:21 AM |
| Install AC Adapter Receptical question | Gdrumm | The Projects Forum | 6 | 01-04-2010 11:17 PM |
| What fries an AC Adapter? | Gdrumm | The Projects Forum | 11 | 07-12-2009 08:22 AM |
| Parallel Wiring Very Simple Question | turzel09 | General Electronics Chat | 5 | 06-22-2009 07:30 PM |
| E-book Help AC Circuit Question | n7dgn | General Electronics Chat | 2 | 06-06-2009 08:31 AM |
