All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-23-2010, 02:22 PM
polter polter is offline
Default wind turbine load control circuit
I have a 5kw ginlong (www.ginlong.com) PMG with a open circuit voltage of 700V at 200 rpm.
I want to use this generator with a wind turbine to heat water without using any batteries at all. The load circuit should include a heating element powered by thyristors.
Is there a ready made control circuit available, or can someone give me a complete circuit that is ready to be put together?
Any help would be much appreciated.
  #2
Old 02-24-2010, 03:59 PM
Bernard's Avatar
Bernard Bernard is online now
Default
I believe 700Vs is a little out of AACs range,'get nervous above 48V.
  #3
Old 02-26-2010, 08:14 AM
Default
Hi Bernard, I can overcome the high voltage easy enough, I think, but what are AAC's?
  #4
Old 02-26-2010, 03:34 PM
Bernard's Avatar
Default
AAC= All About Circuits
  #5
Old 02-26-2010, 03:43 PM
onlyvinod56's Avatar
onlyvinod56 onlyvinod56 is offline
Default
what are the specifications of the heating element?
and what is that generator? Is it an AC / DC generator? If AC, .... 3 phase / 1 phase?
Do u want to use a normal 1000 watt immersion type water heater??
Tags
Related Site Pages
Section Title
Textbook Contactors : Electromechanical Relays
Similar Threads
Thread Thread Starter Forum Replies Last Post
wind turbine simulation in matlab sumitgupta The Projects Forum 3 07-17-2009 01:11 PM
Need help for a dawn/dusk LED circuit malaybiswas The Projects Forum 24 03-04-2009 04:19 PM
stepper motor driver control circuit dingding The Projects Forum 7 08-15-2008 06:12 PM
Simulink of Control Circuit for Soft Start Soft Stop Three-Phase Induction Motor. doinfinity The Projects Forum 0 02-26-2008 11:06 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
