All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-08-2006, 10:14 AM
5aly Msha3er 5aly Msha3er is offline
Red face My Baby Monitoring System
am looking for a circuit that actuate the LEDs and the Buzzer? i want to know what components that i have to use?
May i have your help as soon as possiable, please?
Regards;
5aly Msha3er
  #2
Old 10-08-2006, 02:59 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
Which LEDs? What buzzer? What sequence? What is meant by "actuate?" Do you want to turn them off when your wife comes home? Do you want to turn them on at noon on Wednesday? Do you want them to flash when the temperature in you oven reaches a certain point? Do you want them to fade in and out in time with the local ocean tides?
So far the component list is "LEDs and buzzer."
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #3
Old 10-09-2006, 10:27 AM
Default
This is first Electronic project and am working on (Baby Monitoring system). I decided to place this system in the baby's toys room (3 to 5 years). By placing three motion sensor in the room, the first sensor will be placed to measure the movement in the room, the 2nd sensor and the 3rd sensor will measure if there is a movement nearest to the door or the window. On the other side there is a display box that allows the mother to look after the baby while she work. The box contains of three LED (green, yellow and red) if there is normal movement in the room the Green LED will be ON. if there is a movement near the window or the door the Yellow LED becomes ON. if there is no movement in the room at all the Red LED will work. then the mother will go and check for the baby.
if you want to read more click here OR copy this link and paste:
http://maryammubarak.blogspot.com/2006/09/bps.html
Looking forward to read from you soonly.
Cheers:
^_^
  #4
Old 10-09-2006, 11:04 AM
mozikluv mozikluv is offline
Default Movement sensor
hi,
so you will be using proximity sensors to monitor movements directly headed for the window or door and a motion sensor for the general movements.
as a word of caution, this kind of project is quite hard to implement though making the circuit design is easy. you will have to do a lot of tinkering with the sensitivity of the sensors till you have achieve the desired result.
and another thing, whats the room dimension to start with. the recommendation of what motion sensor to use will depend on this dimensions.
moz
__________________
THE BIGGEST ROOM IN THE WORLD IS THE ROOM FOR IMPROVEMENT
  #5
Old 10-09-2006, 11:43 AM
sci-3d's Avatar
sci-3d sci-3d is offline
Member
Default
For Buzzer please this website
http://www.sixca.com/micro/mcs51/music51/song_51.jpg
For LED, I think it can be easy to find in Google.
__________________
Microcontroller Programming Forums:
http://forum.mcuprogramming.com
Answer to your questions!
Microcontroller Programming Blog:
http://mcu-programming.blogspot.com
uC - News, Resources and Tutorials
  #6
Old 10-10-2006, 08:44 AM
Default
thanks "MOZIKLUV" for the time you offered, i will be looking at the points which you gave to me ^_^
  #7
Old 10-10-2006, 08:45 AM
Default
Another thanks to "SCI-3d" coz am really was looking for this circuit ^_^
  #8
Old 10-16-2006, 12:58 AM
mrmeval mrmeval is offline
Default
You can try GSpy and have it monitor via video. It can be set up for zones I believe though you might have to make modifications for different alert levels.
The computer can be the noise maker or you can drive a signal out the parallel port which can turn on LEDs, buzzers, alarms, etc.
Get a cheap laptop that has USB and some wireless cameras and have fun.
  #9
Old 10-16-2006, 06:58 AM
Smile
thank you (MRMEVAL) for your comments, i think that i could help me if i am thinking about visual disply, but I'm changing my mind to have only LED display.
LOOKING FORWARD TO READ YOUR COMMENTS
  #10
Old 10-16-2006, 08:12 PM
Søren Søren is offline
Default
Quote:
You didn't check the mailaddress at your blog i gather ?
__________________
Regards,
Soeren
>>> Whatever works... Works <<<
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
