All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Closed Thread   Post New Thread
Thread Tools Display Modes
  #1
Old 02-22-2010, 05:36 PM
bd525 bd525 is offline
Junior Member
Default Small 120vac to 12vdc transformer
What is the smallest transformer (step down) that I can use to take 120VAC to 12VDC? I have project that needs 12vdc, but I am told as one of the requirements is not to use a standard wall wart transformer... Can I use a miniature PCB transmformer? Is there a better way to do this?
Thanks!
  #2
Old 02-22-2010, 05:43 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
How much current do you need?
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #3
Old 02-22-2010, 08:33 PM
Junior Member
Default
about 50mA
  #4
Old 02-23-2010, 08:42 AM
t06afre's Avatar
t06afre t06afre is offline
Default
Is this a school project? Because perhaps then your teacher want you to build a simple power supply as part of the learning process. A simple power is made by a transformer,rectifier, filter cap, and linear regulator(s).
Also do not feel afraid to admit that it is a school project. You are welcome to ask your questions here in this forum
  #5
Old 02-23-2010, 11:23 AM
KMoffett KMoffett is offline
Default
http://www.tamuracorp.com/clientuplo...cs/3FS-2XX.pdf about as small as I've been able to find in the past. Available from Digikey...$4. I've also gutted wall-warts for small transformers.
Ken
__________________
"To invent, you need a good imagination and a pile of junk."
Thomas A. Edison (1847 - 1931)
  #6
Old 02-23-2010, 04:26 PM
Junior Member
Default
Hey Guys,
Thanks for all your replies!!
No this isnt a school project. I have been playing with electronics as a hobby and one of my personal projects caught wind of my boss and now had become part of a work project. I am learning as I do this so thats why I am asking questions here to get expert input.
I will check out the link here in a few.
  #7
Old 02-23-2010, 04:44 PM
Junior Member
Default
Thanks for the KMoffet, that might work... also I am going to start hunting some wall warts to see what I can find...
  #8
Old 02-23-2010, 07:01 PM
Default
If you are going to build this device for your employer, I would suggest you not go with cannibalized parts (wall-warts).
Ken
__________________
  #9
Old 02-23-2010, 09:46 PM
Audioguru Audioguru is offline
Banned
Default
A cheap wall-wart AC-DC adapter has horrible voltage regulation. its output might be 12V with lots of ripple at its rated load current but might have an output voltage of 24VDC at a low current.
  #10
Old 02-24-2010, 01:45 PM
Junior Member
Default
Thanks for the warnings guys, I will take your advice and only use the junk parts for my own testing...
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Small input Voltage to Transformer bouncetherabbit General Electronics Chat 2 01-25-2010 04:25 PM
12vdc transformer measures 17.39 with meter. Bad? JeffreyNHouston The Projects Forum 5 02-18-2009 08:10 PM
240vac to 12vdc transformer Help! DinoDave The Projects Forum 5 02-19-2008 11:09 AM
Ideas for 120VAC -> 40VDC @ 700mA transformer given limited volume torinwalker The Projects Forum 6 05-31-2007 02:59 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
