All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-22-2010, 05:23 PM
huntlk huntlk is offline
Junior Member
Default (PNP) Collector Feedback Bias Amplifier Circuit
To bias a (pnp) collector feedback amplifier circuit with a Q point set to approximately 5mA of collector current. Choose a base resistor that will provide a reasonably stiff bias.
VEE = +18V
RC = 1.2k
βDC = 200
All of the circuits that I have dealt with have used VCC. I am not sure how to calculate the RB value. Please help!
  #2
Old 02-22-2010, 08:29 PM
hobbyist hobbyist is offline
Default
This is just a quick guess at your question.
Wait for a while until the real good posts come in, then you can evaluate the correct answer.
I'm only a hobbiest, so take this for what it is...
VCC is noted as collector supply voltage, where negative term. is grounded.
VEE is emitter supply voltagte where neg. term is grounded.
Collector feedback consists of a resistor between collector terminal and base.
Start with quiescent voltage at the collector. for a properly biased amp.
Vcq=?
then with no emitter resistor, solve for base voltage.
Vb= (Vee - Vbe) Vbe is voltage drop between base and emitter.
Vb=?
The base resistor for collector feedback, conects directly between base and collector terminals.
So voltage across base resistor = VRb
VRb = (Vb - Vcq)=?
Now determine amount of base current using Beta and collector current. = Ibq.
First collector current Icq.
Icq= (Vcq / RC)
Ibq= (Icq / Beta)
Ibq=?
Base rersistor= Rb.
Rb= (VRB / Ibq)
Rb=?
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help regarding audio amplifier.. sarang2502 General Electronics Chat 16 04-27-2010 10:16 PM
making inductors coils for 400 watts, high frequency amplifier circuit. whale General Electronics Chat 1 02-04-2010 02:03 PM
Amplifier circuit!?! Urgent Help Needed! johnjoe2000 Homework Help 2 12-06-2009 07:46 PM
power amplifier circuit design salih The Projects Forum 14 11-08-2009 05:19 PM
the term "common" shelly50 General Electronics Chat 27 01-23-2006 04:02 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
