All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-07-2006, 03:39 PM
Jbolt Jbolt is offline
Default DC LED Brightness control
I'm tring to help my 12 year old son with a school project. He wants to build a LED book light with variable brightness. We are finding this to be more difficult than we thought it would. From what I've been able to gather a PWM is necessary. Any help or guidance would be appreciated.
Thanks,
Jay
  #2
Old 10-07-2006, 04:10 PM
beenthere's Avatar
beenthere beenthere is offline
Default
Led's are current-operated devices. There is some maximum value for current, but it can be controlled resistively. A PWM methodology is just overkill.
You need to determine if the led's are to be in series or parallel. White led's need about 2.2 volts applied to go into conduction, so more than a few would make the needed source voltage too high. Placing them all in parallel requires more current.
Say he is planning on using 6 led's. That's too much in series for a 12 volt source. Arranging in two parallel brances of 3 led's each would be better. That way, each branch would need at least 6.6 volts applied. For good brightness, figure on between 15 and 20 milliamps per branch.
Again, assuming 6 led's and 12 volts, subtract the led operating voltage from the applied voltage (12 - 6.6 = 5.4 volts). Above the operating voltage, led's have no resistance, so current has to be controlled with a resistance. For the total current of 40 mills (20 ma per branch), use a 140 ohn resistor. Make it a 1/2 watt resistor. The actual power in the resistor is right at 1/4 watt, so some overhead for safety is a good idea.
To vary the illumination, add a potentiometer in series with the 140 ohm fixed resistor. You might want to use about 1000 or 2500 ohms for a wide range of adjustment before things get too dim. Make sure the pot is rated at 1/2 watt, too.
Radip Shack might have all this stuff.
  #3
Old 10-07-2006, 09:26 PM
mrmeval mrmeval is offline
Default
Rat Shack may have it but the people there no longer are competent to find it. They've shoved all of that stuff in drawers or eliminated it entirely now.
Digikey, Jameco are good, the school may have a source for parts as well.
Tags
Related Site Pages
Section Title
Video Lecture Parallel RC Circuits - Inductors,Capacitors,Transformers
Textbook Millman's Theorem revisited : Dc Network Analysis
Worksheet Series-parallel DC circuits
Worksheet Voltage divider circuits
Worksheet Series DC circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Make your own multimeter : Dc Circuits
Textbook Millman's Theorem : Dc Network Analysis
Textbook Ammeter design : Dc Metering Circuits
Textbook Simple parallel circuits : Series And Parallel Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
triangle wave vs pwm led brightness control Macnerd General Electronics Chat 16 06-02-2014 12:31 AM
Control LED brightness using LDR of a PIC16F hjki The Projects Forum 2 05-05-2014 04:56 AM
Testing an Industrial AC and DC Variable Speed Drives NiCeBoY General Electronics Chat 13 12-08-2013 02:11 PM
LED question - varying brightness Otaku The Projects Forum 7 08-31-2010 01:06 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
