All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-19-2010, 11:04 AM
SheerGold SheerGold is offline
Default Circuit needed to reverse DC supply polarity every 3 minutes
I have a DC supply (12v, 0.1A) that I want to reverse the polarity every 3 minutes or so. The reversal needs to be done automatically as the unit is used fort 3 hours each time. Also I need to be able to manually set the reversal interval between 30 seconds and 5 minutes.
I have another 12v DC supply, but where the current maximum is 2A. I need to do the same with that. This supply is in a damp environment. The other supply is in a dry environment.
Anyone have any ideas of simple circuits that will do that?
  #2
Old 02-19-2010, 12:19 PM
tarar916 tarar916 is offline
Default
u can also use an h bridge with a 555 timer
  #3
Old 02-19-2010, 10:46 PM
Bernard's Avatar
Bernard Bernard is online now
Default
For slight symplification use 555 & DPDT relay.
  #4
Old 02-20-2010, 08:54 AM
Default
Thank you for your advice.
I am a relatively new to electronics. I am also proficient with a soldering iron.
But when it comes to integrated circuits I am lost. So I am unfamiliar with the 555 chip.
I know what a DPDT relay is, but not much about the solid state version.
Are there any simple tutorials that would help me understand how to make the circuit I need?
The DPDT relay needs to be switched every 3 minutes or so. Plus the ability to manually set the interval between switching to between 30 seconds and 5 minutes (for experimental purposes) is important.
  #5
Old 02-20-2010, 11:37 AM
KMoffett KMoffett is online now
Default
Can you tell us what you are switching the polarity to?...a motor perhaps?
Ken
__________________
"To invent, you need a good imagination and a pile of junk."
Thomas A. Edison (1847 - 1931)
  #6
Old 02-20-2010, 11:42 AM
Default
Quote:
Ken
It's a colloidal silver generator. That's simply a couple of silver wires in water. By electrolysis it generates colloidal silver. The switching is to reverse the current every so often to avoid silver oxide building up on the wires.
  #7
Old 02-20-2010, 12:01 PM
retched's Avatar
retched retched is offline
Default
Model railroading has many set-able auto reversing circuits. This is used if you have a round track and you want the trolley to go in one direction for a few min then reverse for a few min. You could add a relay to the output to handle higher voltages.
[ed]
Here is a very adjustable model, you most likely can find off the shelf varieties.
http://www.trainelectronics.com/auto...c/NEW_unit.htm
[/ed]
__________________
-rm-
  #8
Old 02-20-2010, 05:03 PM
Bernard's Avatar
Default
Check AAC books at top of page. volume VI, chapter 8, for 555 circuits,& Bill Marsden's LEDs, 555s, Flashers.
As you need only a few micro amps, a single 555 & a one transistor invertor will provide alternating reversals. Set 555 as close to 50 % as possible. 'would suggest one meg pot from pin 3 to 2 &6, with switch selected capacitors for a short & long time periods. My printer-scanner is down so cannot send print--Help!!
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Control AC device with a DC circuit ke5nnt The Projects Forum 6 02-01-2010 06:49 PM
dc POWER SUPPLY PROBLEM alpha_tayyab General Electronics Chat 7 07-15-2009 05:51 PM
convert circuit from single to dual supply yardcat General Electronics Chat 3 04-25-2009 03:12 PM
Electronic Circuit Design Help Needed. R.Stephen The Projects Forum 4 12-05-2006 08:01 AM
Circuit designers help needed R.Stephen The Projects Forum 1 03-03-2006 09:00 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
