Fixing a motorcycle rectifier/regulator. Can the old rectifier be bypassed?
Status
Not open for further replies.
kiai
Joined Feb 18, 2010
9
So, I've seen a couple posts on motorcycles, but no answers yet.
I've got a 1981 Honda CX500C with a 3-phase alternator. I'm not sure why yet, but this engine puts out a current of up to 24 amps or so, unlike other CX500 bikes that send out less than 20. (Maybe because of the CDI?) The voltage regulator seems to be working, but the rectifier, which is fitted into the same unit as the regulator has a burned out diode or more and the battery is not charging.
I was wondering, if a diode breaks, can I put a new diodes before and inline with the broken unit to get current to the regulator without having to remove the broken rectifier? The diodes are selenium and encased. Doesn't the current take the nearest/shortest path?
Thanks!
MikeML
5,444
Do you have a factory wiring diagram of the system? If yes, please post it. The rectifiers can fail either open or shorted. I would have to see how they are deployed to figure out if they can be left in?
kiai
Joined Feb 18, 2010
9
The attached is all they provide as far is wiring is concerned. Output must be 14-15V. There is a 30-amp fuse before the battery.
If I can't put 6 new diodes before the old rectifier, what should the voltage regulator have? A resistor in series with a zener diode, parallel to a transistor? I'm not sure how to spec that besides volts.
Can I use three Radio Shack diodes before the Zener diode and resistor? Would the rectifier have to convert AC to DC before the voltage sensor? I have a lot of questions.
retched
Joined Dec 5, 2009
5,207
If a diode fails open, (or anything for that matter) just consider it not there.
If it fails closed, consider it a wire.
I had a CX500 Turbo from around the same vintage (more or less the same engine, different packaging). I never dug into the wiring, but from a quick surf around the web, it looks like Honda used the same setup they use on all the other Hondas I've ever owned (I think the Goldwing and maybe ST1100/1300 are different). Anyway, that setup is:
Permanent-magnet 3-phase generator;
Bridge rectifier; and
Zener-like voltage regulator
The rectifier and regulator are potted into the same package. I've often had diodes fail in the R/R, and when that happens, you either blow a fuse (if the diode fails short) or don't get enough charging current and run the battery down (if it fails open). Either way, you have to check the generator coils, because they often get damaged too.
You can replace Honda R/Rs with aftermarket ones (I've used Electrosport R/Rs with some success) and you can also use OEM units from other brands. I've heard that Yamaha makes some MOSFET-based units that are more rugged than the Hondas, you might be able to find a used one at a junkyard for a good price.
You can, theoretically, build a unit that's more robust than the OEM, but it's not easy or inexpensive. You just need a big 3-phase diode bridge and a REALLY BIG shunt -- the faster the engine runs, the higher the voltage. The R/R really just shunts enough current to ground to pull the generator voltage down to 14V or so, low enough to keep from boiling the battery.
I've wanted to build an inductive buck/boost controller for a while, but it's a lot harder than it looks to get everything working in such a harsh environment, plus you have to make it small enough to fit!
The best bet, if you prefer riding to tinkering, is to buy a replacement R/R, mount it to the frame with heat sink grease, and maybe add a 12V CPU fan that runs while the bike is running.
kiai
Joined Feb 18, 2010
9
A shunt! I was wondering if it was necessary. But doesn't the 30 amp fuse work to keep the battery from boiling?
I know how to build the rectifier; though according to that schematic attached, are those diodes leading to the voltage sensor also working as rectifiers?
I want to build a more robust unit. The bike runs. The battery simply isn't charging. (Isn't that failing closed? So, the current is AC still, not DC?) I had a rectifier problem on a CL360. I installed a new Radio Shack rectifier. Works fine now.
retched
Joined Dec 5, 2009
5,207
The fuse ultimately would protect the battery, but then after the fuse blows, the alternator is still pumping out juice. And, you don't want the fuse to blow in standard operation. The shunt will dissipate the power that the battery doesn't want. And THEN if there is a dangerous amount, the fuse blows.
MikeML
5,444
The six diodes used to rectify the three-phase stator windings are similar to what is used in automotive applications except that these are likely rated at about 25A at ~200PIV. What is different is the three Silicon Controlled Rectifiers (SCRs). They are triggered by the Voltage Regulator (VR), and effectively short the stator winding on a half-cycle by half-cycle basis, thereby reducing the average voltage output. These would also be required to stand off > 100V, and be capable of conducting ~25A.
Replacing six power rectifier diodes and three SCRs is not going to be cheap. Plus, you will have to devise a means for mounting them and heatsinking them. How much does Honda charge for the entire rectifier/VR module?
kiai
Joined Feb 18, 2010
9
I can get one used for $60-90. If this part is the same specs as the other cx500s with 20-amp instead of 30-amp fuses, I could bid on one that's on eBay currently at $8. It's probably the same, right? Same generator output, same battery. I think the ignition is a little different.
If I knew which direction the diodes run in this piece, though, I'd drill through, cut the rectifier diodes and solder in my own. It's selenium. What can it do? Release a little toxic gas? Hehe.
kiai
Joined Feb 18, 2010
9
Believe it or not, Honda made selenium rectifiers in the 70s. My 75 CL360 had a selenium rectifier, until I changed it.
wingerr
Joined Oct 24, 2005
8
I wonder if the mechanical load on the engine changes much with the regulator shunting the stator output current vs. when it's delivering the current out to an electrical load.
With an automotive charging system, the mechanical load changes depending on the power requirements, because the field current is adjusted to suit, but on this R/R setup, it doesn't seem like you'd save any gas by minimizing the electrical loads, unless when the stator windings are shorted out completely, the mechanical load goes away.
kiai
Joined Feb 18, 2010
9
I really doubt that the rectifiers are Selenium. Even 1960s cars had Silicon Rectifiers (Not SCRs) in their alternators.
Here is some other info.
YOU WERE RIGHT, MikeML! The Clymer manual is wrong. There are a lot of errors in the Clymer manual for the CL360. In the Honda manual, it says it's a silicon rectifier.
kiai
Joined Feb 18, 2010
9
Hmm, Wingerr, I'll have to think about that. :confused::):D:cool::rolleyes:
Status
