Hey guys,
I'm having some trouble with some math code used for my PIC16F684.
Don't worry about the A/D conversion, I just deleted the other code. The problem I'm having is that I don't believe the second if statement is working properly. I want to take the absolute value of "gain" but my compiler doesn't have the absolute function. Instead I just put "-gain" which compiles fine and I think works.
When output > 0, the PIC outputs a PWM square wave which shows up fine on the oscilloscope. It's when output should be < 0, the output on the oscilloscope is a very strange square wave, that looks noisy and has weird superimposing square waves. I think the problem is with the math though.
Can someone verify if the way I initialized the variables will properly store data? I get confused when I'm doing math with mixes of signed and unsigned numbers.
I'd appreciate the help a lot. Thanks!
Rich (BB code):
int16 PV, SP;
int16 E0;
uns8 gain;
int16 output;
uns16 temp;
SP = 128;
PV = ADRESH; // ADC value = ADRESH (8 MSbs)
E0 = PV - SP;
output = gain*E0;
if(output > 0){
P1M1 = 0;
temp = output;
temp /= 4; // Shift bits 3 to 10 of temp twice to the right
CCPR1L = temp;
if(output < 0){
P1M1 = 1;
temp = -output;
CCPR1L = temp;
