All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-16-2010, 08:02 PM
rougie rougie is offline
Member
Default 3.3 volts to 5Vdc level shifter
I am using the MAX607ESA DC to DC convertor. My circuit is exactly as the one shown on P.7 of the spec. I need to send a binary high or low signal to the pin 4 input of this device. I need my high/low voltage range to be approximately 0.002 (low) to 5 (high) VDC.
The source of the signal that is to go to this input comes from a CPLD which outputs 3.3VDC only. The CPLD is the EPM240T100C5N device from Altera.
I have tried to connect the CPLD output to a 1K resistor and then to the gate of a 2n2222 transistor. The collector of the transistor connects to a 270ohm resistor and the other side of the resistor connects to a +5VDC power source.
When my CPLD ouputs a low, I get 4.9 VDC at the collector. When my CPLD is high, I get .002 VDC which is a typical low. So now everything works fine.
The moment I connect the collector to pin #4 of the DC to DC convertor input, my 4.9 VDC at the collector becomes 2.92 VDC.
Why?
All help very appreciated.
PS I am not to experienced in this sort of stuff... any guidence can be very helpfull to me. Thanking all in advance!
Ross
  #2
Old 02-16-2010, 08:40 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Default
You didn't make it any easier by omitting the datasheet of the MAX607ESA.
Basically, you're trying to supply the current to run the DC-DC converter through a 270 Ohm resistor. That won't work well, as the resistor will limit the input current too much.
Do it like this instead:
Q1 turns on Q2 via the 200 Ohm resistor, which limits base current to around 20mA. The 2.2k resistor keeps Q2 turned off when Q1 turns off.
Q2 sources the current to the MAX607 pin 4. It'll handle up to perhaps 300mA current wired this way.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #3
Old 02-16-2010, 08:48 PM
Ron H's Avatar
Ron H Ron H is offline
Default
I haven't used this part, but it appears that the correct way to switch the output on and off is to provide +5V to pin 4 and switch the part on and off with pin 3. It appears you can do this directly from the CPLD.
  #4
Old 02-16-2010, 09:02 PM
Member
Default
Thanks SgtWookie,
Right now I can't try your circuit because I don't have Q2 in hand. I only have a 2n3904. So I will go and purchase a 2n2907 PNP transistor and try it.
I really appreciate your help. Thank you!
Ross
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Voltage Level Shifter lmartinez General Electronics Chat 13 11-06-2009 01:22 AM
Home made level shifter help snoop The Projects Forum 3 11-02-2009 01:30 PM
Voltage Level Shifter Circuit mikewilliams The Projects Forum 12 06-05-2009 10:07 PM
level shifter: 12 to 5 volts-PWM lmartinez General Electronics Chat 23 03-12-2009 01:17 AM
Can we use a tristate buffer in place of voltage level shifter? sharath_412 General Electronics Chat 2 05-25-2007 03:12 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
