You can solder with an electric griddle, so I suppose you could desolder an IC with a griddle also? After it is heated up, use something (tape on a stick) to lift the IC out? If it helps, the solder holding the IC down is leaded. Thanks!
Does this work well for high pin DIP? I have a number of 40 pin dip sockets I can salvage.I would go with the heat gun technique more so than a blow torch!! Atleast with a heat gun you can slowly heat the board until the solder melts.....
What I usually do is heat the PCB with the component I want to remove with a heatgun from the solder side..... once the solder melts, I tap the PCB onto my benchtop and the components fall right off. You can slowly heat the PCB and give it a tap to see if the solder has melted enough for the components to come off, this way you would be less likely to overheat the component. I use this technique in salvaging through hole components and surface mount components, and also for board repairs...
My .02
Bless you my brother!! I just picked up a heat gun at Harbor Freight. Turns out it was a sale item this month. I snagged it for $10.You may want to consider a heat gun.
Using a griddle, you may spend too much time trying to soften the solder. The heat gun works great. I use it for de-soldering to salvage off old boards. As long as the griddle gets above melting temperature, it should work, however there is alot of heat going other places besides the chip you want it on.
I have never tried the griddle method.
For pulling IC's I use a pair of small channel locks that I plasti-dipped the jaws. You can also slide the rubber handle covers off an inch, cut them off and pull them over the jaws.
by Duane Benson
by Duane Benson
by Aaron Carman
