| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#1
Hi
I'm looking for a miniature 12 position potentiometer. specifically a 1.1k pot that switches up in 100 Ohm increments between 0 and 1.1k I've found one from an automotive supplier but it costs over £120! so I'm thinking of building a digital circuit that does the same thing. If anyone has any advice on how best to go about this, or where to source a cheaper switched pot than the one I've found then it would be much appreciated. Cheers |
#2
If you're going digital, and what you really want is a rotary control that has "clicks" or detents, I'd guess it'll be a LOT cheaper to use a rotary encoder.
http://www.bitechnologies.com/pdfs/en11.pdf Hook it up to a digital pot: http://datasheets.maxim-ic.com/en/ds...60-MAX5468.pdf and Bob's your uncle! Last edited by spacewrench; 02-14-2010 at 07:14 PM. Reason: [added digital pot info -- 99 cents from Mouser!] |
#3
Try a 12 position rotary switch with 100 ohm resistors soldered between the terminals. The link is for one supplier's choices - http://www.futurlec.com/SwRotary.shtml
__________________
First comes the hardware, then the software. |
| Bookmarks |
| Tags |
| position, potentiometer, switched |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Toyota Throttle Position Sensor | MikeML | General Electronics Chat | 20 | 03-16-2010 11:28 PM |
| Using a potentiometer to control a relay at fully clockwise position | littlelabs | The Projects Forum | 2 | 10-28-2009 09:23 PM |
| Potentiometer for LED Dimming | mpangrekar | General Electronics Chat | 6 | 07-28-2009 02:53 AM |
| Potentiometer Help | MikeNdaMaddawg66 | The Projects Forum | 4 | 06-05-2009 04:15 AM |
| Needed: 9v, potentiometer driven, LED circuit | nctech | The Projects Forum | 37 | 05-22-2009 01:59 AM |
