All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-14-2010, 06:01 AM
johntee johntee is offline
Junior Member
Default Using diodes on a relay for spike protection
Hi folks. On the attached schematic, there's a diode on the coil of the relay, to protect the system from the coil spike when the relay opens.
Does it matter which way the 1N4004 diode is "pointing"? i.e., is a clamping diode always stopping positive from reaching negative, or vice-versa, or doesn't it matter?
Would it hurt/help/not matter to also include another diode "pointing" in the opposite direction across the same wires? (Since the diodes are so cheap, and some of the electronic components so expensive.)
Would I need another diode on the Timer Relay? If so, between which wires, and in what direction? ("A1" and "A2" are constant, with a trigger signal coming in on "S" to kick off the timer.)
With those diode(s) in those locations, would all the components of the system be adequately protected?
Relays:
--- 782XBXM4L-12D Magnecraft Electromechanical Relay, "Ice-Cube" Style, 16A DPDT, 12VDC Coil Specs
--- And the socket for it: 70-782D-1 Magnecraft Relay Socket, 8-pin Cube Style, 2 Pole, 16A, 300V, IP 20 (Finger-safe) Specs
--- Time-Delay Relay to feed 120VAC lighting circuit: 822TD10H-UNI Magnecraft 10 Function Programmable Time Delay Relay, 15A DPDT, Universal Coil Voltage 12 - 240 VAC/VDC Specs
Thanks for your help/thoughts!
John
  #2
Old 02-14-2010, 06:55 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Your diode as shown will short the 12v supply when the access control NO connection closes. This will either fry the diode to a crisp, cause the 12v supply to shut down, blow a fuse in the 12v supply, or cause other undesired events to occur.
The diode must be installed so that the cathode (end with the band) is towards the more positive supply to the coil (reverse biased).
The "spike" occurs when the current to the coil is suddenly turned off. The magnetic field around the coil collapses, which "tries" to keep the current flowing in the same direction as it was when it was powered. This can cause very high peak reverse voltages unless there is a reverse-EMF diode (sometimes called a "flywheel" diode) installed. The diode provides a path for current back through the diode.
A single diode per coil is usually sufficient.
Sometimes a Zener diode is used in series with a standard rectifier diode. This causes the current to decay more quickly. In this case, the standard diode's cathode still goes towards the more positive supply, but the Zener's cathode goes towards the more negative.
There are also TVS diodes: http://en.wikipedia.org/wiki/Transie...pression_diode
The timer module is electronic; it doesn't need external diodes.
However, you are switching the current to the 120v/24v transformer's primary. This will cause similar spikes when power is disconnected. You may wish to include TVS suppression across the inputs/outputs of the transformer.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
The Following User Says Thank You to SgtWookie For This Useful Post:
fiskle (03-09-2013)
  #3
Old 02-14-2010, 05:16 PM
Junior Member
Default
Hi Sgt. Thanks for the quick and informative reply.
A few questions --
In my application, do you think I would need the Zener diode you mentioned?
Without a TVS diode on the transformer, what components would be at risk? Would the spike remain on the primary side (and thus feed the spike back to the electrical panel)? (Which should be able to handle it without incident?) Or would the whole transformer or its secondary side (and the door strike) be at risk also?
If I do really need a TVS diode on the transformer, do you know what model # would be a good choice? (Primary is a 120VAC line, transformer's secondary is 24VAC, 20 Watts). I looked at some spec sheets, but swiftly got in way over my head...
Thank you!
John
Tags
Related Site Pages
Section Title
Worksheet Thyristor application circuits
Worksheet Zener diodes
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Worksheet Basic electromagnetic relays
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Protective relays : Electromechanical Relays
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Textbook Commutating diode : Discrete Semiconductor Circuits
Textbook Zener diodes : Diodes And Rectifiers
Textbook Inductor commutating circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Unwanted voltage on open relay contacts. NM2008 The Projects Forum 10 05-09-2009 01:07 PM
Is there a formula to calculate Protection diodes for relay coils? Feign General Electronics Chat 9 03-31-2009 12:07 PM
Relay contact protection. martian The Projects Forum 1 09-05-2008 12:13 PM
EFI Fuel Relay Problem akajee The Projects Forum 4 01-26-2008 08:18 PM
2 Protection diodes needed in different directions across motor = short circuit? thomast The Projects Forum 3 10-31-2006 10:31 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
