All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-24-2009, 03:14 AM
ELECTRONERD's Avatar
ELECTRONERD ELECTRONERD is offline
Default Project: A Variable Power Supply Using the LM338
Hello Everyone,
Just recently I've designed and built my own power supply using the LM338 voltage regulator. I find it to be satisfactory; providing a adjustable voltage range from 1.2V to roughly 29.8V. The output ripple ranges from -60dB to -54dB (1mV to 2mV) when the voltage is within 1.2V to 29V. However, if I go over 29V, I receive a noisy saw-tooth wave whose peak reaches 50mV (-26dB). Clearly, the operation is best suited from 1.2V to 29V and no farther. For more information in addition to some pictures, please visit this site:
http://electrobird.net/Analog%20Proj...ble%20PSU.html
I thank all of you for your contributions to my power supply, It works like a charm. I've already used it to power several other projects of mine.
Thanks,
Austin
  #2
Old 02-12-2010, 07:12 PM
bertus's Avatar
bertus bertus is online now
Super Moderator
Default
The Projects Collection (as opposed to The Projects Forum) is for sharing completed projects. I've moved your post into The Projects Forum, where it will draw more responses.
Can you post the schematic, to see where the humm is coming from at the higher voltage output.
Good luck with your project!
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 02-12-2010, 08:57 PM
Default
Thanks Bertus, this is the perfect place to put it!
Austin
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Portable DC powered variable power supply. brom77 The Projects Forum 1 10-23-2009 01:33 PM
Switching Power Supply cannot power up welcomb The Projects Forum 6 10-20-2009 07:51 PM
Switching power supply with a dead (0v) "low" side FalconFour The Projects Forum 8 01-08-2009 11:37 PM
Pedalboard power supply - help dimi3 The Projects Forum 13 10-30-2008 01:20 PM
Charging batteries with a variable power supply Jacquesl General Electronics Chat 7 04-12-2007 09:28 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
