Intermittent Relay...
aq_rules
Joined Oct 28, 2009
168
Hey,
These Days I was working on a home work project, its a team work,our task was to turn a simple car into a completely sensor loaded car...well our car is equipped with all the sensors which were required but now we want to place a wiper on the rear glass(windshield,i dun noe ny better word for this)....we are done with the fitting nd all other procedures but now what we want is an intermittent relay switch circuit which turns on the wiper for 2 seconds and stops for 5 seconds and repeat the cycle until the switch is turned off.....i hope u guyz getting this...
It would be better if u guys would upload some schematics....i want a simple schematic which only have the electronical components and a relay,not the wiper motor nd all those things, because i'll simply connect the loose wires which i've left under the cars steering...so i'd like to see the basic circuit diagram....
Plzz help..
beenthere
Joined Apr 20, 2004
15,819
Okay - put base1 to ground and place the relay coil between +12 volts and base 2. When the UJT fires, the wiper will start a cycle.
Wendy
Joined Mar 24, 2008
23,429
I just back from work (OT), when I get a chance I'll see what I can do. I've been catching up on the forum whilst eating my raisin bran.
How long do you want it to stay off as a maximum duration?
A suggestion, go through my various threads and blog, and see what comes closest to working for you. When I get back I'll help out, either tweaking your solution or suggesting something I think is better. This way you get some practice designing. It is more than half the fun I think, and if it works you get bragging rights (if it doesn't it's my fault :D).
Wendy
Joined Mar 24, 2008
23,429
Quick question, did this start off as a working windshield wiper? In other words, does it finish a cycle if you turn the wiper off before it has finished moving?
PM is the way to go contacting me. I don't handle technical questions via PM, but I usually honor requests to look at a thread and give feedback. I suspect most of the guy around here do that.
It is now my bed time, I work vampire hours (go in to work at 10PM, get off at 7AM).
Wendy
Joined Mar 24, 2008
23,429
OK, let me break this problem down, you need a waveform something like this...
The fixed duration is around 1 second, the variable can be from ½ seconds to 10 seconds (or more).
A standard 2 resistor 555 astable produces the inverted version of this waveform. This is not really a problem though.
I do not know the circuit of the intermittent wiper motor. I can only assume it has power to allow it to finish a wipe, and a switch input to allow it to turn on. In other words, 3 wires. I would probably go this route...
I pulled and modified the schematic from my cookbook sections in my blog...
http://forum.allaboutcircuits.com/blog.php?b=381
CR1 basically separates the time on from the time off, each resistor controls one or the other. It messes with the math a little, but overall the effect is worth it.
Ron H
Joined Apr 14, 2005
7,063
Bill, I'm not intending to nitpick here. I think your drawings would make a lot more sense if you made a few changes. As it was, your timing diagrams were confusing to me. Attached are my suggestions, with the changes circled (ovalled?) in red.
retched
Joined Dec 5, 2009
5,207
Father Of Satan?
Former Outlaw Skier?
Fabric Oil Stain?
Fighting Orc Sage?
I haven't seen Bill around at all today...yet..
