All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-10-2010, 04:50 PM
CON_ENG's Avatar
CON_ENG CON_ENG is offline
Junior Member
Send a message via Yahoo to CON_ENG
Default impulse generator circuit
Hi every body ,
i am looking for a circuit that produce impulse signal as a part from my project i search in google and i found this circuit .G1 and G2 are gas discharge tube GDT .it is my first time to use this component and i'd like to know is this from 2-pole type or 3-pole. and if it was 2-pole why it's symbol had 3 point? i'd like to know how this work ?and if you had any limitations for using this circuit please, inform me.and if you had any other circuit can do the same function i'd be grateful
Regards
  #2
Old 02-10-2010, 05:48 PM
beenthere's Avatar
beenthere beenthere is offline
Default
It would be helpful to know the application of this circuit. Without an isolation transformer, the circuit is inherently unsafe to use at all.
__________________
First comes the hardware, then the software.
  #3
Old 02-11-2010, 06:30 AM
CON_ENG's Avatar
Junior Member
Smile
i know that but i'll perform this circuit at a low level of voltage so i'll not need it or it will be not neccessary.
now i need to now the type of gas discharge tube, and certainly thanks.
  #4
Old 02-11-2010, 09:30 AM
JDT JDT is offline
Default
The black dot in the symbol signifies that the tube is filled with gas.
These tubes change from insulating to low resistance at the voltages shown. They return to an insulating state when the current falls to some low value.
So in this circuit C3 charges up slowly through R3 and R4. When a voltage is reached, it will discharge quickly through G1 causing a cascade discharge through G2.
The circuit is not polarity sensitive so, depending on which button is pressed, pulses of either polarity can be produced.
Low voltage operation not possible! Take care!
  #5
Old 02-11-2010, 11:21 AM
KMoffett KMoffett is offline
Default
Gas discharge tubes trigger in the 90VDC to 120VDC range, so the circuit can't be used with "a low level of voltage".
Ken
__________________
"To invent, you need a good imagination and a pile of junk."
Thomas A. Edison (1847 - 1931)
  #6
Old 02-11-2010, 03:17 PM
CON_ENG's Avatar
Junior Member
Default
-so, the gas discharge tube used is from 2-pole type.
-i mean by low value of voltage is 500v value . i know that this circuit is not safe .
but i need a circuit that generate impulse signal and this is the avaliable one.
  #7
Old 02-11-2010, 03:20 PM
beenthere's Avatar
Default
The circuit is simply a fatal accident waiting to happen.
Can you give any details about the pulse itself? What does it do and what are the necessary characteristics? There is probably a safe way to make your pulse.
__________________
  #8
Old 02-11-2010, 03:22 PM
bertus's Avatar
bertus bertus is online now
Administrator
Default
The circuit is not safe.
Take a look at a relaxation oscillator.
Here is an example using an UJT.
http://hyperphysics.phy-astr.gsu.edu...ic/relaxo.html
This is a link from the EDUCYPEDIA with oscillators:
http://educypedia.karadimov.info/ele...alogsquare.htm
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #9
Old 02-11-2010, 03:41 PM
CON_ENG's Avatar
Junior Member
Default
ok i need to generate an impulse signal such like lightning strikes but certainly not have the same value i need it as apart from my graduation poroject "lightning and surge protection in photovoltaic installations" so i don't had speciall characteristics except that i need it had an effective value with avery short duration .
  #10
Old 02-11-2010, 04:47 PM
beenthere's Avatar
Default
That gives no useful parameters, like voltage and duration. You might think of using an ignition coil to make a high voltage. There is no connection to the power line, so you have a greater degree of safety involved, plus a greater voltage - http://www.madteddy.com/igncoil.htm
__________________
Tags
Related Site Pages
Section Title
Worksheet Encoders and decoders
Textbook Ionization (gas-filled) tubes : Electron Tubes
Textbook Gas discharge tubes : Thyristors
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Impulse response function estimation sytem_recon Programmer's Corner 3 05-11-2009 03:57 PM
impulse generator snp2411 The Projects Forum 4 03-11-2009 09:48 PM
The derivative of a unit step function is the impulse functions Joe24 Math 6 01-27-2009 01:57 AM
Finding a system impulse response. wiz0r Homework Help 14 11-30-2008 05:12 PM
Digital: Impulse Response (Z-domain) Management Homework Help 0 09-11-2008 10:10 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
