| Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help. |
Thread Tools | Display Modes |
#1
![]() I do not know how this is scaled. The circuit is a forward biased diode with a resistor in series, hooked up to a voltage source of a sin wave with the voltage peak at 1.3v. The graph is the voltage across the resistor with respect to the diode. Last edited by Waffles; 02-08-2010 at 01:01 AM. |
#2
It's impossible to tell. The color coding implies that the vertical amplifier's gain is at 200 mV per division, but you don't know if the input is being attenuated through a probe or not. The best you can probably do is assume it's 200 mV per division and be cognizant that you might be off by a factor of 10.
| Bookmarks |
| Tags |
| graph, oscilloscope, osiciliscope, scaled |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Graph Non-linearity Calculation | thavamaran | Math | 4 | 07-02-2009 01:09 PM |
| voltage-to-current converter chip for oscilloscope XY mode for curve tracing? | relicmarks | General Electronics Chat | 7 | 04-07-2008 03:32 PM |
| HELP!!!...plotting graph of components V and A | raza88sab | Homework Help | 4 | 10-23-2007 12:25 AM |
| oscilloscope modes chop,alternate,add | relicmarks | General Electronics Chat | 1 | 10-13-2006 01:23 PM |
