| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#1
My son & I are attempting the Lemon "battery" experiment (6 lemons connected in a series hoping to light a bulb) and we are baffled by the conclusion. After linking 6 lemons (using gator clip electrodes; 14 gauge copperwire & galvanized nails in each lemon) we were able to detect 4.5V! Great, but why won't our bulb light? We tested each bulb with a 1.5V battery and they work fine. We have tried a variety of tiny bulbs (ie. small bulb in science kit & diodes). We are stumped and if anyone can shed some "light" on the situation that would be greatly appreciated. It would make his science fair project that much more exciting for him. Thank you, Michele |
#2
What kind of lightbulb are you using? What voltage and what current does it need? The lemon batteries can not deliver much current. Greetings, Bertus
__________________
You don't have to know everything, if you know where to find it. When you do ask questions, you may look stupid. When you do NOT ask questions, you will STAY stupid. It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile. (User CP -> Edit Your Details) |
#3
There are many Lemon Battery experiments on the internet. They all say, "The two lemon batteries combine to produce a voltage of 1.788 volts. This combination still does not create enough current to light a small light bulb."
They show the battery dimly lighting an LED. An incandescent light bulb uses 90% of its input power to make heat and only 10% of the power to make light. Maybe you can connect many (10 to 100) lemon batteries in series-parralel to make enough current to light a bulb. |
#5
Instead of a light bulb, how about an LED? You will still need a lot of lemon batteries, but a fraction of what a light bulb would need.
The color red is the most efficient, 2 batteries in series will cause some light. Every 2 after that put in parallel, and the LED will get a little brighter. The problem you are fighting is the current from each is just too low to be useful. You could use larger area of metal disks (I'm assuming you're using coins), the extra surface area would increase the current. This is the same as using multiple batteries. You might also think of using a clock, since they are low current devices too. Another alternative is to charge a capacitor, which will flash a light bulb when connected to it. This would demonstrate storing energy for use in a high energy application later.
__________________
.. "Good enough is enemy of the best." An old engineering saying, Author unknown. General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie. Last edited by Bill_Marsden; 02-08-2010 at 10:01 AM. |
#6
I'd guess the current available is at least partly proportional to the battery 'plate' areas - can you use strip metal rather than wire in the lemon, or lots of separate strands connected together to give more surface & reactive area?
You may still not light a filament bulb, but the LED will be brighter.
__________________
Robert Jenkins. |
#7
I had a lemon clock that ran for about 6 months on a pair of lemons.
__________________
REAL men don't need voltmeters. |
| Bookmarks |
| Tags |
| battery, confusion, experiment, lemon |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| mixing battery in a battery pack | mrel | General Electronics Chat | 3 | 01-26-2010 09:43 PM |
| Question about temperature dependence of Battery capacity | steveb | General Electronics Chat | 39 | 11-26-2009 11:16 PM |
| power circuit with battery needed | router_help | The Projects Forum | 3 | 01-04-2009 07:30 AM |
| Li-ion Battery Charger and Laptops | iONic | The Projects Forum | 7 | 12-27-2008 10:43 PM |
| ALKALINE BATTERY CHARGER | lildiesel6075 | The Projects Forum | 32 | 06-22-2007 12:51 AM |
