All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-05-2010, 03:47 AM
loosewire loosewire is offline
Default What the genius of Calibration
An ohm meter you short the leads together and ajdust to zero.
Who discovered calibration and what does it stand for. How many
types of curcuits can you list that need calibration.Are calibrations
a parts of designing a curcuits. What happen to fine tuning your
radio dial, was it design or f.c.c.-Does space flight have calibrations
Are there still signal generators that produce continueous signals
thru the spectrum.Is there calibration in the chip world of compondants.
What type of curcuits and why.
  #2
Old 02-05-2010, 04:38 AM
nsaspook's Avatar
nsaspook nsaspook is offline
Default
There are calibration standards for everything. Most are traceable to these guys. http://ts.nist.gov/MeasurementServic...s/Services.cfm
For semiconductors most primary standards are sourced from here. http://www.vlsistandards.com/
I handle most ISO/TS calibration audits at work. It's a hell of a lot of paperwork and very expensive.
  #3
Old 02-05-2010, 09:38 AM
rjenkins rjenkins is offline
Default
Calibration basically means adjusting the circuit or whatever to do what you want.
As an example, if you made a LED bar VU Meter to display an audio signal level, you would include some facility for adjustment so you can make the full scale display correct for the actual maximum level of the analog signal it's working from.
That is a form of calibration.
For a voltmeter, it would be adjusting to give an accurate reading of the actual voltage being measured.
It's not specific to electronics, all forms of measuring device are calibrated to some extent, such as a micrometer for measuring small objects or a the gas company meter that they use for billing.
__________________
Robert Jenkins.
  #4
Old 02-05-2010, 02:57 PM
nsaspook's Avatar
Default
AUDIT HAT ON
Calibration does not mean adjustment. Calibration is comparing a measuring instrument of unknown accuracy to a measurement standard (traceable) of known value and uncertainty. Adjustment of the unknown instrument is a possible option to reduce the error to within the stated tolerance of the instrument.
Quote:
International vocabulary of basic and general terms in metrology (ISO, 1993):
"A set of operations that establish under specified conditions the relationship between values of quantities indicated by a measuring instrument or measuring system, or values represented by a material measure or a reference material, and the corresponding value realized by a standard.
Notes: 1. The result of a calibration permits either the assignment of values of measurands to the indications or the determination of corrections with respect to indication.
2. A calibration may determine other metrological properties, such as the effect of influence quantities.
3. The result of a calibration may be recorded in a document, sometimes called a calibration certificate or a calibration report."
http://www.agilent.com/metrology/cal_or_verify.shtml
  #5
Old 02-05-2010, 07:17 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
E-book Developer
Default
I managed to serve a year in a metrology lab, which gave me a bare taste of it. I did the factory floor test equipment, next door was our standards lab, which calibrated or made sure the equipment we used was calibrated (as in sent to the national labs).
It's funny, in many ways the better you can measure the less accurate everything seems. Not true, but it seems that way, because you can quantify the error.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oscilloscope Calibration Unit with LTC6655 ELECTRONERD The Projects Forum 7 02-05-2010 03:21 AM
calibration of weight device ghanim General Electronics Chat 6 02-02-2010 11:39 AM
What do we mean by calibration in Digital wattmeter bhanu27 The Projects Forum 1 01-26-2010 02:55 PM
Calibration drift? magneto259 Radio and Communications 8 05-18-2009 11:56 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
