All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-04-2010, 12:51 PM
sabbi sabbi is offline
Smile why output of op amps is finite to +dc and -dc supplies
why output of op amps is finite to +dc and -dc supplies?
i mean why ouput of op amps ca have any value between +Vcc and -Vcc?
  #2
Old 02-04-2010, 01:18 PM
Mike33 Mike33 is offline
Default
An opamp needs a little power to operate, so most of them never get quite out to the V+ and V-. Those are the "power rails". SOME can operate very close to the rails, however!
An amplifying device can only give out as much as is put in - by the input signal and the power supply. You are using the input signal to control how much of the power supply becomes the output. You can't get more out than there is to offer from the power supply! That would violate the laws of conservation of matter, LOL.
Check out the E-books on here, and use Google to look up "amplifying device tutorial", "opamp tutorial" and the like. There is much information about this out there, for free! :o)
  #3
Old 02-04-2010, 03:15 PM
KL7AJ KL7AJ is offline
E-book Developer
Default
Yep that's the universal "No Free Lunch" law.
__________________
REAL men don't need voltmeters.
  #4
Old 02-04-2010, 08:43 PM
russ_hensel russ_hensel is offline
Default
But you could build an op amp with a few hidden charge pumps inside and get more than rail to rail output. Conservation of energy applies to energy, not to voltage. I do not know of any such device, but a max232 sort of does it.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Variable DC Input Volatge, Constant DC Output Voltage mdweiss The Projects Forum 8 01-28-2010 09:22 PM
Can i use 2 DC power supplies together? GARYN The Projects Forum 7 09-06-2009 04:52 PM
Output of hphones logic level DC mxabeles The Projects Forum 3 06-25-2009 05:10 PM
12v dc 200ma output to 13v dc 1.3a motor? artistwood General Electronics Chat 4 06-20-2009 05:55 PM
SMPS Vs Transformer for 4KVA DC output Bhargavkr The Projects Forum 2 06-18-2009 07:50 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
