I know nothing when it comes to electrical stuff and i am wondering how i can increase the amps of 12v DC
A fallacy out there is that it takes more energy to produce the HHO than the energy it releases.
I just don´t understand this "much more efficient" design.Raise amps from a given voltage source by lowering resistance.
An ordinary car battery will provide plenty amperage for electrolysis. If you need more still, hook up a second battery in parallel.
Please excersise all appropriate safety precautions - hydrogen explosions maim and kill.
Your alternator will constantly be recharging your battery...its not like you are using every ounce of energy that the battery is to hold.....The alternator will always recharge your battery anyway so why not create your own fuel from that left over electricityI just don´t understand this "much more efficient" design.
If I use the energy from the battery to create H2 + O2 to add it to the fuel, then I recharge the battery from alternator (generator?) where is any improvement?
The energy balance in the system just gets worse, so if I were to run such a car, how often will I have to recharge the battery?
Left-over electricity? Of course not.Your alternator will constantly be recharging your battery...its not like you are using every ounce of energy that the battery is to hold.....The alternator will always recharge your battery anyway so why not create your own fuel from that left over electricity
by Aaron Carman
by Jeff Child
by Duane Benson
